Oil Filter Interchange Question ??? #85796
07/08/08 01:59 PM
07/08/08 01:59 PM
Wisconsin
Aero426 Offline OP
Aero426  Offline OP
Wisconsin
Dumb question. I'm going to order some Wix filters on the group buy deal.
My '70 Roadrunner takes the full size Mopar filter. My '93 D150 takes the shorter Mopar filter with the full size base. But... assuming the full size filter fits (it does), is there any disadvantage to using the full size filter and just order one part number?
Re: Oil Filter Interchange Question ??? [Re: Aero426] #85797
07/08/08 02:46 PM
07/08/08 02:46 PM
P
Paul_Fancsali Offline
P
As long as it bolts on and clears use either one. I prefer the short ones over the long ones for ease of getting off/ on in a tight space
Re: Oil Filter Interchange Question ??? [Re: Paul_Fancsali] #85798
07/08/08 02:56 PM
07/08/08 02:56 PM
More filtering area is a plus. 51515
Re: Oil Filter Interchange Question ??? #85799
07/08/08 04:01 PM
07/08/08 04:01 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Me too - 51515 is all I use, plus it's easy to remember the part number.
Re: Oil Filter Interchange Question ??? [Re: Aero426] #85800
07/08/08 04:57 PM
07/08/08 04:57 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
Length--Fram-----Purolator--Wix
2.48"---PH3512---L10101------xxxxx
3.79"---PH16-----L14670-----51085
4.39"---PH43-----L20081-----51068
5.18"---PH8A-----L30001-----51515
6.98"---PH977A---L40017-----51773
All above are 3.25" in diameter
3.40"---PH3614---L10241-----51348
The above is 3.00" diameter (2.0 Neon filter)
I too think bigger is better.
I use Purolator L30001 on everything (Hemi, 440, 225) except my Neon which gets the L20081 because the L3001 hangs down below the oil pan.
Re: Oil Filter Interchange Question ??? [Re: B5 Bee] #85801
07/08/08 05:13 PM
07/08/08 05:13 PM
Wisconsin
Aero426 Offline OP
Aero426  Offline OP
Wisconsin
All good info - thanks guys!
Re: Oil Filter Interchange Question ??? [Re: B5 Bee] #85802
07/08/08 11:36 PM
07/08/08 11:36 PM
Palm Coast, FL (near Daytona B...
Blown_Hemi Offline
Blown_Hemi  Offline
Do you have a cross reference for Napa Gold filters for the Wix 51515 and Wix 51773?
Ask me my opinion of Frank Mitchell....... A Mopar crook!
Re: Oil Filter Interchange Question ??? [Re: Blown_Hemi] #85803
07/09/08 12:02 AM
07/09/08 12:02 AM
San Jose, Ca. -- Honolulu, Hi.
Green_RB_Dart Offline
ALL Napa gold filters are Wix. To get the Napa
number, just drop the first numeral from the
Wis number. Example; Wix 51515 = Napa 1515
Wix 51773 = Napa 1773.
Re: Oil Filter Interchange Question ??? [Re: Green_RB_Dart] #85804
07/09/08 02:34 AM
07/09/08 02:34 AM
Blown_Hemi Offline
Blown_Hemi  Offline
Thanks. I googled "oil filter cross reference" and found out about dropping the first numeral.
Re: Oil Filter Interchange Question ??? [Re: Blown_Hemi] #85805
07/09/08 06:42 AM
07/09/08 06:42 AM
I use the 51068 on my Neons and it even fits my 2.2. The 51515 was too long for the Neons, it was much lower than the oil pan so I use the 51068 now.
Re: Oil Filter Interchange Question ??? #85806
07/09/08 10:51 AM
07/09/08 10:51 AM
Lost in the ozone again
stubbs300 Offline
Vacation
stubbs300  Offline
Vacation
Just because a filters longer doesn't mean that it filters more or better. It's what's inside that counts! http://www.knizefamily.net/minimopar/oilfilters/index.html
Re: Oil Filter Interchange Question ??? [Re: stubbs300 ] #85807
07/09/08 02:17 PM
07/09/08 02:17 PM
Blown_Hemi Offline
Blown_Hemi  Offline
I just picked up a pair of Napa Gold #1773 filters for my next oil change. I am using dual remote filters and am waiting on my Brad Penn 10 W 30 oil. The filters cost $10.50 a piece at Napa. Thanks for the info and cross reference chart.
