Depends on the intake !!!!
Read my posts starting on page 2 of this thread
Scott - Bee1971
https://board.moparts.org/ubbthreads/show...part=1&vc=1Same issues with my 71 Superbee
End of last summer i switched to a Synthetic oil and a Holley Street Dominator intake on my numbers matching 383 - Started going through oil like crazy - This spring i switched back to a convential oil like i have been using for the last ten years since the engine was gone through -Car never has burned a drop of oil since rebuild before
Anyways i discovered something when pulling the plugs and doing a compression test - All cylinders on the passenger side spark plugs had carbon buildup - Drivers side plugs were perfect and clean - Well light tan in color and looked great
All eight cylinders had compression of 135 - 150 #s
Anyways i have never used a paper gasket on the valley tin pans that i have installed for the last twenty years on big block mopars
The car idles and runs perfect - 750 rpms at idle with a Edelbrock 800 cfm carb and that used Holley Street Dominator intake - Engine .030 over / Mopar 284/484 cam and 906 heads gone through ten years ago
Was cruising to a car show this past weekend and the only time oil was noticed out the exhaust from my buds behind me was when letting off the throttle - PASSENGER SIDE EXHAUST PIPE ONLY
Time to pull the intake ??? Or head ??? Or both
Try some paper gaskets on the tin valley pan ???
Could it pull oil from the bottom of the tin pan to one head only ??? The intake bolted up fine with no vacuum leaks - Idles and runs perfect
Anyways i am scratching my head , no pun intended
Figured i would bring up this old thread that i found instead of starting a new one
Scott
Found the intake bolts to bee on the loose side last week
After a good retorque , took it for a nice long haul - No good , still used a little oil
This past Friday pulled the carb off - Oil in the bottom of the intake - Pulled the intake off and was plain as day
Could see oil around the intake ports - I had ordered the Fel Pro Intake Gaskets just incase , for the valley pan so i was good to go - Cleaned everything up and installed the fiber gaskets (Four) to the valley pan using Permatex copper sealant/spray
Retorqued the Street Dominator Intake to 25 ft# and everything looked good - Went to a car show today in Two Rivers WI , about 150 miles roundtrip
Came home and pulled the dipstick after the engine was cold - Not a drop of oil - PERFECT PERFECT PERFECT
Something so simple but yet so stupid for me not thinking about it earlier - I was thinking synthetic oil or a head - Rings
First time i have had an issue with just using the tin valley pan on a Big Block Mopar - Valuable lesson learned i guess - Some intakes require those fiber gaskets
Scott
