906 heads advice
#85765
07/08/08 11:12 AM
07/08/08 11:12 AM
Posts: 847 Parsons (SouthEast) Kansas
funkyjbp
mopar addict
mopar addict
what will 906 heads with 2.14 intake and 1.81 exhaust valves, and the mopar performance porting template modifications do in a stock compression 63 413? i also can get a stock 375 horse magnum cam (new) with a three bolt double-row timing set to also install in the 413. the motor is out of 63 chrysler 300 2 door and has been rebuilt prior to me getting it. it runs really well with the stock heads/cam/intake. i plan for an Edelbrock RPM manifold and it will have a 3.55 or 3.91 sure-grip. i have a holley street avenger 75 double pumper and 1 & 3/4 inch headders with 2.5 dual exhaust, flowmasters and crossover tube for exhaust. it is all in a 71 shortbed truck that i am converting from street to mild bracket racing duty. just curious to know what the compression would be, stock 413 heads on motor, and then with the 906s on the stock 413. what do you think the 375 hp cam would be like in the 906 combination? thanks, JP in KS.
71 SWB, 413
77 SWB, 318
92 SWB, 5.2 magnum
79 Macho Short bed, 318
03 stratus coupe R/T
too many others not on the road!
Re: 906 heads advice
[Re: JohnRR]
#85767
07/08/08 12:55 PM
07/08/08 12:55 PM
funkyjbp
mopar addict
mopar addict
johnrr are you the guy with mid america customs in the st. louis area? if so, want to talk about the door panels and a set of coils springs. 620-820-3793 later, jp in ks.
71 SWB, 413
77 SWB, 318
92 SWB, 5.2 magnum
[Re: JohnRR]
#85769
07/08/08 03:50 PM
07/08/08 03:50 PM
funkyjbp
mopar addict
mopar addict
no sweat, i figured it out after i posted. later, jp.
71 SWB, 413
77 SWB, 318
92 SWB, 5.2 magnum
