1969 Roadrunner convertible,, HEMI power #856463
11/17/10 11:56 PM
11/17/10 11:56 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
While the Cuda is out getting the top and headliner installed this was in the shop today.
Nothing major , Just a little bit of work.
Making some new trans cooler and fuel pump to carb lines. and fixing some leaks in the rear axle. and tried to fit some subframe connectors.
It is a real RM27 car , but born with a 383
It's one of the Mopar stock bore / stroke 426 crate motors .
Enjoy!
Re: 1969 Roadrunner convertible,, HEMI power [Re: gtx6970] #856464
11/17/10 11:58 PM
11/17/10 11:58 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
power plant
Talk about one cold natured sonofagun
Re: 1969 Roadrunner convertible,, HEMI power [Re: gtx6970] #856465
11/18/10 12:00 AM
11/18/10 12:00 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Trying to make trans lines from scratch with the engine/trans in car,, top it off with TTI headers in the way was almost fun,,almost
Re: 1969 Roadrunner convertible,, HEMI power [Re: gtx6970] #856466
11/18/10 12:01 AM
11/18/10 12:01 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
The easy end
Re: 1969 Roadrunner convertible,, HEMI power [Re: gtx6970] #856467
11/18/10 12:04 AM
11/18/10 12:04 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Subframe connectors fit , I'll just say was far less than ideal.
Re: 1969 Roadrunner convertible,, HEMI power [Re: gtx6970] #856468
11/18/10 12:05 AM
11/18/10 12:05 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
other side, same side of the car
Re: 1969 Roadrunner convertible,, HEMI power [Re: gtx6970] #856469
11/18/10 12:05 AM
11/18/10 12:05 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
again
Re: 1969 Roadrunner convertible,, HEMI power [Re: gtx6970] #856470
11/18/10 12:07 AM
11/18/10 12:07 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
drivers side rail isn't near as bad,but is going to take some work to make fit
Re: 1969 Roadrunner convertible,, HEMI power [Re: gtx6970] #856471
11/18/10 12:28 AM
11/18/10 12:28 AM
Fairfield Maine
hemi4speed Offline
hemi4speed  Offline
Fairfield Maine
Bill nice RR, did the frame connectors come from US Tool? Just bought a set from them, I havent put them on yet.
Re: 1969 Roadrunner convertible,, HEMI power [Re: hemi4speed] #856472
11/18/10 08:56 AM
11/18/10 08:56 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
I'm not 100% sure ,,,but I think he bought them from XV motor sports
Re: 1969 Roadrunner convertible,, HEMI power [Re: gtx6970] #856473
11/25/10 09:52 PM
11/25/10 09:52 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
Nice! Really needs 2x4's! A good friend of mine bought a 426 625 hp crate motor. It only had 570 at the flywheel with the single 4. He went to the stock 2x4's and got 620 hp with no other changes.
