wicked 440 build up ideas? #85566
07/07/08 11:03 PM
07/07/08 11:03 PM
Anonymous OP
Anonymous OP
ok what would be a quick boost in power ive put cam intake carb ignition indexed plugs played with timing all kinds of stuff i was thinking about puttin in an underdrive kit any body used a good under drive kit? im gettin the nos sniper kit 359.99 or somethin like that ok and what about fuel and oil coolers a demon carb performer rpm intake instead of torker 2 i just want some ideas i can reuse when i pull the engine out this winter oh and its a 440 with a lunati 60302 cam and spring kit what about a turbo i wanna go kinda crazy here any body ever used one
Re: wicked 440 build up ideas? #85567
07/07/08 11:17 PM
07/07/08 11:17 PM
Watertown, WI
MikeyT Offline
MikeyT  Offline
Watertown, WI
Here this is a nice buuild idea right here!
The defacto 500 hp build
http://www.moparts.org/Tech/Archive/bb/59.html
read it, a good build and has made a lot of people very happy!
Mike
1969 Dodge Dart Swinger
Re: wicked 440 build up ideas? [Re: MikeyT] #85568
07/07/08 11:24 PM
07/07/08 11:24 PM
Anonymous OP
Anonymous OP
yea i was planning this build for another car but i want something COMPLETELY DIFFERENT for this build thats why i was asking about turbo and stuff cuz how many 440s do you see with a turbo? i want a crazy build just one nasty 440 thats nobody ever seen before untill i turn it into a 543
Re: wicked 440 build up ideas? #85569
07/07/08 11:31 PM
07/07/08 11:31 PM
Anonymous OP
Anonymous OP
oh come on people nobody ever had anything they wanted to try on a 440 any ideas at all...MONEY IS NO PROBLEM i want just plain crazy ideas to build power and be different!!!!
Re: wicked 440 build up ideas? #85570
07/07/08 11:53 PM
07/07/08 11:53 PM
Anonymous OP
Anonymous OP
send me $17000 and i'll ship you the CRAZIEST 440 you've ever seen.
Re: wicked 440 build up ideas? #85571
07/08/08 12:09 AM
07/08/08 12:09 AM
missouri, USA
moparmojo Offline
moparmojo  Offline
missouri, USA
Well you have the right concept. Being quick is really about throwing money at it. How quick do you want to go. There are all sorts of guys running fast on Nitrous. Get the right cam, nitrous, converter and gearing and your set. However, a decent respectable say 150 shot and you can still do well and fairly cheap. Turbos are kool if you can build a set up to work. I saw someone out there had a corvette setup that had the turbos out in the back of the car running off the exhaust. There was some pressure loss due to the extra travel, but overall it seemed to work nicely and you didn't have to cram it into the engine bay. Give it a shot.
Re: wicked 440 build up ideas? #85572
07/08/08 12:44 AM
07/08/08 12:44 AM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
www.1962to1965mopar.ornocar.com/mmo82001.html
Re: wicked 440 build up ideas? [Re: Triggerfish] #85573
07/08/08 12:49 AM
07/08/08 12:49 AM
Anonymous OP
Anonymous OP
Re: wicked 440 build up ideas? #85574
07/08/08 04:05 AM
07/08/08 04:05 AM
Anonymous OP
Anonymous OP
i want to build on even more bada** that that and that is sweet!!!i loveing the ideas keep them comeing .i want it fast REAL FAST.
Re: wicked 440 build up ideas? #85575
07/08/08 08:52 AM
07/08/08 08:52 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
well boost it and instead of NOS get a meth-H2O injection kit. You won't even need a cooler. I'd probably supecharge it. Easier and you don't have to hack up your engine compartment. If you're talking about a basic 440 for the street. Get a set of good light rods/pistons, roller cam, E-heads (or similar), headers, RPM intake, Holley 950DP, and a stall and gear to match your cam. Then hit it with a 200 shot. Depending on you car and the set-up your could be in the 9-10 second range.
Re: wicked 440 build up ideas? [Re: Mr.Yuck] #85576
07/08/08 09:56 AM
07/08/08 09:56 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Gunnar, your posts come off as the wild rantings of a teenager that has big dreams.
If you spend a little time here reading, there are some wild motors already. A twin turbo street car, a C body that's deep in the 8s, a 632 Cu In. drag motor.
If you really do have unlimited funds and want to build an outrageous motor, why would you post about building more power without rebuilding?
https://board.moparts.org/ubbthreads/showflat.php?Cat=0&Board=QuestionAnswer&Number=4445835
Then ask about a common torque spec? Do I need to go on?
Define what intended use you have in mind, a realistic budget, and ask what people suggest. You will get integlligent, informed answers.
Re: wicked 440 build up ideas? #85577
07/08/08 10:50 AM
07/08/08 10:50 AM
missouri, USA
moparmojo Offline
moparmojo  Offline
missouri, USA
Looks like that motor was eaten by an octopus.
Re: wicked 440 build up ideas? [Re: moparmojo] #85578
07/09/08 12:05 AM
07/09/08 12:05 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Do a turbo then. STSturbo does the rear mounted turbo setups. Run it with a small amount of boost, say 5-7 psi, then when you rebuild, crank it up higher. But in reality, you are probably better off saving your money towards rebuilding the motor itself. You can buy the goodies now that you'll reuse like carb, intake, headers, aluminum heads, etc so that when rebuild time comes, it's easier on the wallet.
