904 deep trans pan question #85418
07/07/08 06:52 PM
07/07/08 06:52 PM
65Valiant Offline OP
super street
super street
Hey all, I want to put this pan on my 904 tranny yet need a filter extension right?
the pan is 1 7/8 inches deep yet has these cooling fins on it
any help on the right filter extension would be great
thanks!
Re: 904 deep trans pan question [Re: 65Valiant] #85419
07/07/08 06:53 PM
07/07/08 06:53 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
No filter extension needed, the cooling tubes take up the extra depth.
Re: 904 deep trans pan question [Re: 65Valiant] #85420
07/07/08 06:56 PM
07/07/08 06:56 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
IMO ... you can do much better with a regular MP pan. Those tubes are just a gimmick.
A separate trans cooler works much better.
Re: 904 deep trans pan question [Re: dOc !] #85421
07/07/08 07:16 PM
07/07/08 07:16 PM
super street
super street
great,
thanks guys!
Re: 904 deep trans pan question [Re: dOc !] #85422
07/07/08 08:45 PM
07/07/08 08:45 PM
Bristol, Va
fasteddie Offline
fasteddie  Offline
Bristol, Va
Really?
Chrysler engineers thought it worked well enough to use it on heavy duty transmissions.
It will help keep the trans cooler.
I use one on the Dart Bracket car along with a cooler in front of the rad. I also use a trans fluid thermastat to help get the trans up to operating temp.
2003 Bristol Dragway Sportsman Champion
2016 Bristol Dragway Power Hour Champion
Re: 904 deep trans pan question [Re: fasteddie] #85423
07/07/08 09:45 PM
07/07/08 09:45 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
Really ? ....and what application was that? An OEM part ? ...what was the part# ?
Re: 904 deep trans pan question [Re: John_Kunkel] #85424
07/07/08 09:51 PM
07/07/08 09:51 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
I am running the same pan, and saw my engine temp drop nicely after installing the pan. The design is very sound, lots more surface area in contact with the oil and with the air outside, I don't think you could add enough fins (or long enough fins) to a cast aluminum pan to get the same heat transfer.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: 904 deep trans pan question [Re: dOc !] #85425
07/11/08 02:02 PM
07/11/08 02:02 PM
Bristol, Va
fasteddie Offline
fasteddie  Offline
Bristol, Va
We don't need no steenking part #.
It is standard equipment on my 89 Dodge 3/4 ton van with the towing package. This van is used to tow the race car to the track. 999 truck trans (heavy duty 904)
The one on the race car came from the junk yard. The trans was already out of the vehicle so I can't tell you what it was in.
