collector gaskets #85378
07/07/08 04:46 PM
07/07/08 04:46 PM
central Il.
garymac Offline OP
garymac  Offline OP
central Il.
What is the best 3" collector gasket? I have ceramic coated headers and exhaust what gaskets are the best? Just a street car. I have heard that copper is good. thks garymac
Re: collector gaskets [Re: garymac] #85379
07/07/08 04:48 PM
07/07/08 04:48 PM
NY
W
WICKD6PK Offline
WICKD6PK  Offline
W
NY
copper or high temp sillycone .......
Re: collector gaskets [Re: WICKD6PK] #85380
07/07/08 05:00 PM
07/07/08 05:00 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Its the only place I use the copper gaskets.Had them on the headers and they leaked like a sieve.The collectors seal good with them.I use Summits as they are cheaper than a name brand.Rocky
Chrysler Firepower
Re: collector gaskets [Re: therocks] #85381
07/07/08 05:13 PM
07/07/08 05:13 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Copper with copper hi-temp rtv. Eternally reusable and blow-out proof. If your collectors step down in size buy the copper. If the exhaust pipe is the same size as the collector you can run any gasket since there should not be any restriction at that point in the system.
Re: collector gaskets [Re: garymac] #85382
07/07/08 08:44 PM
07/07/08 08:44 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
If you don't want leaks buy REMFLEX gaskets
Re: collector gaskets [Re: RJS] #85383
07/07/08 09:48 PM
07/07/08 09:48 PM
I used the steel reinforced felpro ones over and over with out any problems. I had bad luck with the mr. gasket white colored ones.
Re: collector gaskets #85384
07/08/08 04:31 PM
07/08/08 04:31 PM
central Il.
garymac Offline OP
garymac  Offline OP
central Il.
Thanks guys, I'll pick some up wed. Thanks again, garymac
