Hemi and B/RB cams the same? #85236
07/07/08 12:23 PM
07/07/08 12:23 PM
Anonymous OP
Anonymous OP
Silly question but I need to know. I know the basics of the blocks are the same save for cross bolted mains on the Hemi and extra head bolts but can you use a B/RB cam in a Hemi?
Re: Hemi and B/RB cams the same? #85237
07/07/08 12:42 PM
07/07/08 12:42 PM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
No, the valve layout is different, therefore the lobe arrangement along the shaft is different. It will physically fit the block, but it would not work
Re: Hemi and B/RB cams the same? #85238
07/07/08 12:44 PM
07/07/08 12:44 PM
Virginia
HemiStan Offline
HemiStan  Offline
Virginia
No. The lobes on the Hemi cam are in different locations than the B/RB cams.
