57 Plym leaf spring replacement #851555
11/11/10 10:38 PM
11/11/10 10:38 PM
SD
Z
zrxkawboy Offline OP
Z
SD
I am replacing the leaf springs on my 57 Belvedere. What have you guys done about the fabric wrap around the springs where they meet the rear axle? Is there a good substitute, or can it be omitted? It is not even shown in the FSM diagram. Thanks!
It's Swifty! Swifty, you toad sucker!
Re: 57 Plym leaf spring replacement [Re: zrxkawboy] #851556
11/12/10 09:08 AM
11/12/10 09:08 AM
SD
Z
Z
SD
bump
Re: 57 Plym leaf spring replacement [Re: zrxkawboy] #851557
11/12/10 10:42 AM
11/12/10 10:42 AM
Clintwood VA
johnedod Offline
johnedod  Offline
Clintwood VA
I've added a couple of leaves to my 68 road runner and I didn't use anything between them. So far I haven't had any ill effects. I know the fabric you are talking about. The 65 Fury I had used the same stuff. I guess it was to keep down squeaks and/or to keep the leaves from wearing into each other. I don't have a clue what it is or where you'd find it. I know later they used plastic between the leaves. Good luck!
Johnedod
68 Road Runner
71 Road Runner
78 Power Wagon
Re: 57 Plym leaf spring replacement [Re: johnedod] #851558
11/12/10 11:08 AM
11/12/10 11:08 AM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
i think it can be left out. i`m not sure whey they wrapped the leafs. for those who don`t know what he is talking about here is a pic of the leafs on my 47 desoto-
Re: 57 Plym leaf spring replacement [Re: 65rbdodge] #851559
11/12/10 12:21 PM
11/12/10 12:21 PM
Clintwood VA
johnedod Offline
johnedod  Offline
Clintwood VA
Wow! Maybe I didn't know what he was talking about after all! My Fury had little fabric "pads" between the leaves and that's what I assumed he meant. I didn't know they used to completely wrap them like that. Thanks for the pic! You learn a lot on this site.
Johnedod
68 Road Runner
71 Road Runner
78 Power Wagon
Re: 57 Plym leaf spring replacement [Re: johnedod] #851560
11/12/10 03:48 PM
11/12/10 03:48 PM
Indiana, Just Off I-70
BradD Offline
BradD  Offline
I believe the springs were rapped for both quietness and to keep dirt out. Dirt between the springs is like sand paper. They probably stopped using it because of cost and dirt and water would still get in them eventually. I don't believe they are necessary. If it were a top notch resto, then I would wrap them.
Brad
Check out the Dorn's 69 Barracuda "Switchblade" in the Nov.2010 MCG
Check out the Dorn's refurbished 36 Ford in the Feb.2011 Street Rodder
Re: 57 Plym leaf spring replacement [Re: BradD] #851561
11/12/10 08:31 PM
11/12/10 08:31 PM
SD
Z
Z
SD
Thanks for the replies. On mine, it is a thin, white, canvas-like material, and it is only wrapped around the springs where they bolt to the rear axle. My thinking was that it was to eliminate any noise, and I'll probably be fine without it. Thanks again.
Re: 57 Plym leaf spring replacement [Re: zrxkawboy] #851562
11/13/10 10:07 AM
11/13/10 10:07 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
My 57 Chrysler didnt have any wrap.I replaced the springs because the mains were snapped.The new ones had no wrap and I drove it for 6 years.The 41 Plymouth my kid has they have wrap.Rocky
Chrysler Firepower
