Is anyone running a CS144 alternator on their bigblock?
#850802
11/10/10 10:17 PM
11/10/10 10:17 PM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
If you are, did you have any issues with the install? I know it's a Delco-Remy product, but the thing puts out between 80 and over 100 amps at idle, 140 amps stock, can be reliably modified to put out over 200 amps and is easily adapted to the big block Mopar mount with a simple add-on bracket. I found it too hard to pass up, especially since I've added a significant amp load with fuel pump, fans, MSD ignition, A/C etc.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
Re: Is anyone running a CS144 alternator on their bigblock?
[Re: jbc426]
#850803
11/11/10 02:21 PM
11/11/10 02:21 PM
jbc426
West Coast, USA
Most Mopar lovers may not be that familiar with this alternator, it is the latest sweetheart for the power-hungry, high-output alternator crowd. These alternators come on many late model GM trucks, Silverados, Escalades, Tahoes etc.
I discovered it while doing research on upgrading and wiring my electrical system. The ball started rolling in this direction after I started talking with Mark Hamilton of Mad Electrical. As you may know, he's not at all impressed wtih the idle output of any of the Mopar alternators, their amp guages and related wiring layouts.
I've taken his years of experience one step further by going with a high-output, remote-voltage sensing CS144 alternator instead of the 12si or CS130 alternators he's fond of.
Another tip for my fellow Mopar brothers and sisters, is regarding sourcing electrical accessories such as wire and cable lugs, fused DC power distribution components and high amperage fusable battery accessories. I found most of the parts I am using to upgrade, route, distribute and fuse my high-current portion of my electrical system at marine parts stores.
That's right. Boat and ship makers have some really nice, heavy-duty components that are Coast-Guard approved in many cases for safely wiring the high-current DC electrical systems such as we have in our cars once we start adding electrical accessories. I also found them to be better made, corrosion and moisture resistant/proof and much more reasonably priced in a lot of instances.
Do a little search on Google for marine grade electrical accessories the next time your thinking of tinkering with your electrical system. They have some cool things available there that I have never seen available elsewhere such as high-amp, battery terminal fuse block studs and well-though-out high-amp fused DC distribution panels.
It's really worth a look. Here's a picture of the main DC power distribution hub on my project in progess. I made a plate to mount everything that bolts onto the stock battery tray mounts. I don't like drilling extra holes in the car and avoid it whenever I can. -Notice the little fused panel to the right of the Spal fan controller- cool 'eh & cheap!
I'll post some more once I move forward in this process of installing more DC power-related stuff including some of the marine grade fusing saftey features. The CS 144 is at the alternator shop getting upgraded with heavy duty voltage regulator, bridge rectifier and stator. I'll post some pictures of it on here when I get them too.
