E-body power window - hole size for wiring harness #85044
07/06/08 11:31 PM
07/06/08 11:31 PM
Maple Ridge, BC, Canada
Barnabas_Kriss Offline OP
Anyone know the correct hole sizes for the grommets for the PW wiring harness? I need sizes for both the door and the door pillar.
Re: E-body power window - hole size for wiring harness [Re: Barnabas_Kriss] #85045
07/07/08 07:33 PM
07/07/08 07:33 PM
Fla
birdboy Offline
birdboy  Offline
Fla
if this helps a 71-up b body is 1 1/2 on cowl side and 1 1/4 on door.
Re: E-body power window - hole size for wiring harness [Re: Barnabas_Kriss] #85046
07/07/08 09:34 PM
07/07/08 09:34 PM
B.C.
mk_ Offline
mk_  Offline
B.C.
Hi Barnabas, I measured up the power window holes on my 70 E body project today:
Drivers pillar and passenger pillar are 1.5" and the drivers and pass door are 2.0".
Re: E-body power window - hole size for wiring harness [Re: mk_] #85047
07/07/08 09:51 PM
07/07/08 09:51 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I thought there was a very good thread about this within the last 6 months or sooner.
Pictures of gomments and variations in the hole size, IIRC.
Re: E-body power window - hole size for wiring harness [Re: autoxcuda] #85048
07/08/08 02:40 AM
07/08/08 02:40 AM
Thanks everyone!
Re: E-body power window - hole size for wiring harness [Re: autoxcuda] #85049
07/08/08 05:00 PM
07/08/08 05:00 PM
cataclysm80 Offline
cataclysm80  Offline
Yes, I started that thread. I was surprised that mopar used different grommet sizes/combinations on each body style.
Here ya go...
https://board.moparts.org/ubbthreads/show...&PHPSESSID=
Tav
Re: E-body power window - hole size for wiring harness [Re: mk_] #85050
07/08/08 05:11 PM
07/08/08 05:11 PM
cataclysm80 Offline
cataclysm80  Offline
Did you make those holes yourself? I'm thinking they should each be about 1/8 inch smaller so that the grommet fits tight and doesn't fall out.
Tav
Re: E-body power window - hole size for wiring harness [Re: cataclysm80] #85051
07/08/08 08:42 PM
07/08/08 08:42 PM
B.C.
mk_ Offline
mk_  Offline
B.C.
Tav
These measurements are from my original 70 340 E body with factory power windows.
The holes in the pillars measure about 1.510" and about 2.065" on the doors, and the factory grommets fit snug.
Re: E-body power window - hole size for wiring harness [Re: mk_] #85052
07/09/08 10:41 AM
07/09/08 10:41 AM
cataclysm80 Offline
cataclysm80  Offline
Thank you for measuring and posting that info. It's very helpfull.
Is the car also a 4 speed car, or a cruise control car? There is another hole I was wanting a measurement for.
Tav
