J-Body tailpipes... Should I use B/E/or A-body??? #85041
07/06/08 11:27 PM
07/06/08 11:27 PM
Tampa, FL
tpabayflyer Offline OP
Tampa, FL
I want to run the tailpipes on my 83 Cordoba 390 project all the way out to the back as the turndowns after the magnaflows is a bit loud....... I have made things much easier by getting rid of the stock gas tank as I have a 16gal fuel cell in the trunk now so plenty of room for tailpipes.
I'm thinking about using my Summit Bucks and getting some flowmaster 3" for B-body but I am not sure about the fit. The E-body ones are a 2 piece design that fit under valence.
Anybody run a 3" exhaust on their F/J/M bodies???? TBF
Re: J-Body tailpipes... Should I use B/E/or A-body??? [Re: tpabayflyer] #85042
07/06/08 11:55 PM
07/06/08 11:55 PM
Tampa, FL
Tampa, FL
I should also mention that there is a local shop that can mandrel bend 3" tubing so that is an option as well. I am using hooker super comp headers, 1 3/4 tubes and 16" magnaflow straight through mufflers...... TBF
71 Challenger 528 Hemi project
09 Gr Cherokee 5.7 hemi in da house!!
Re: J-Body tailpipes... Should I use B/E/or A-body??? [Re: tpabayflyer] #85043
07/07/08 01:40 AM
07/07/08 01:40 AM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
That's what I would do.
