TTI 1 7/8 Header install on A-Body 69 Dart S/B #848720
11/08/10 11:16 AM
11/08/10 11:16 AM
c/r B.C. Canada
Guber2 Offline OP
Guber2  Offline OP
c/r B.C. Canada
Have any of you tryed this one??????
P/S ,Indy 360-1's
Re: TTI 1 7/8 Header install on A-Body 69 Dart S/B [Re: Guber2] #848721
11/08/10 01:40 PM
11/08/10 01:40 PM
wisconsin
kmfdm Offline
kmfdm  Offline
wisconsin
i got a set of their W-2 headers on mine. No p/s but they went in easy.
74 Dart Sport
Re: TTI 1 7/8 Header install on A-Body 69 Dart S/B [Re: kmfdm] #848722
11/08/10 01:55 PM
11/08/10 01:55 PM
c/r B.C. Canada
Guber2 Offline OP
Guber2  Offline OP
c/r B.C. Canada
they hit the extra head bolt boss on the left side of the 360-1 and hint the torsion bar on the right side .I just hate to bang up a 1000.00 set of headers to make them fit.
Re: TTI 1 7/8 Header install on A-Body 69 Dart S/B [Re: Guber2] #848723
11/08/10 03:26 PM
11/08/10 03:26 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Make sure the engine is located properly per the instructions.
Re: TTI 1 7/8 Header install on A-Body 69 Dart S/B [Re: RobX4406] #848724
11/08/10 04:17 PM
11/08/10 04:17 PM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
I had to grind the extra boss a little and the head twrd the rear same head.I was lucky I did a fit test motor out. As far as the bar you can move the motor around to clear but its close . Mine hasnt hit but I use the poly lock mounts.
Let me know if you need pics.
Re: TTI 1 7/8 Header install on A-Body 69 Dart S/B [Re: Scamp408] #848725
11/08/10 10:31 PM
11/08/10 10:31 PM
c/r B.C. Canada
Guber2 Offline OP
Guber2  Offline OP
c/r B.C. Canada
I was glad to fine I was not alone on this one.
I've got the poly loc mounts as well.
got my heads off and on there way to Ryan J.
I'll have him take off the extra boss's
Re: TTI 1 7/8 Header install on A-Body 69 Dart S/B [Re: RobX4406] #848726
11/09/10 03:16 AM
11/09/10 03:16 AM
c/r B.C. Canada
Guber2 Offline OP
Guber2  Offline OP
c/r B.C. Canada
sorry cant read
Re: TTI 1 7/8 Header install on A-Body 69 Dart S/B [Re: Guber2] #848727
11/09/10 08:04 AM
11/09/10 08:04 AM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
pic
just those 2 spots have to be touched
Re: TTI 1 7/8 Header install on A-Body 69 Dart S/B [Re: Scamp408] #848728
11/09/10 01:58 PM
11/09/10 01:58 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
pic
so the indy heads have provissions for stock boltpattern headers? looks like it from the pic or is that a hopelles thought,thinkinh the ports may be raised to much anyway?
