exhaust manifold bolts/1970 440
#84797
07/06/08 12:56 PM
07/06/08 12:56 PM
I promise this will be the last question on this subject. I seems what I need are three 1-1/4" by 9/16" bolts with a allen wrench hole in them for the three recessed holes in the manifold. Am I correct and where would I get them?
Re: exhaust manifold bolts/1970 440
#84799
07/06/08 01:46 PM
07/06/08 01:46 PM
Sounds like you didn't bother reading the answers to your other exhaust manifold question.
#84800
07/06/08 05:31 PM
07/06/08 05:31 PM
actually I did but now I find out that there is no bolts used, everything is studs with nuts. I finally got it right.
#84801
07/06/08 07:23 PM
07/06/08 07:23 PM
Posts: 486 NJ
SlimJim
mopar addict
mopar addict
NJ
You are still incorrect. Please, click this link to Mancini Racing http://chucker54.stores.yahoo.net/oemexmastnu.html You need two long barrel nuts and one short barrel nut.
#84802
07/06/08 08:40 PM
07/06/08 08:40 PM
Posts: 74,970 U.S.S.A.
JohnRR
U.S.S.A.
you could have just kept the first thread going instead of having multiple threads on the same subject , less confusing for everyone involved .
and there are actually 2 different size tube nuts , the one for the drivers side is SHORTER than the 2 required on the passenger side .
#84803
07/06/08 09:38 PM
07/06/08 09:38 PM
#84804
07/07/08 12:06 AM
07/07/08 12:06 AM
JohnRR
U.S.S.A.
now you've done it
[Re: JohnRR]
#84805
07/07/08 10:03 AM
07/07/08 10:03 AM
now you've done it
what awnsered with a picture ?
