E-body power brake linkage repop available? #84681
07/06/08 08:58 AM
07/06/08 08:58 AM
Long Island NY
ErikR Offline OP
ErikR  Offline OP
Long Island NY
Anyone know if there are reproduction units available for the linkage that joins the brake pedal to the booster?
Re: E-body power brake linkage repop available? [Re: ErikR] #84682
07/06/08 07:30 PM
07/06/08 07:30 PM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
Erik,
I don't know of any being made as a repop. There was a pretty good thread on this a while back. I bought one on Ebay that was said to be for an E-body and found that it would not work on my car w/o modification. I then found another one that would work. I'm still not sure what the issue is unless one is for a 4 spd car and one for an Automatic. Just make sure you get the right one.
EDIT>>> HERE's the link Erik. https://board.moparts.org/ubbthreads/show...rue#Post4329801
Joe
65 Barracuda
70 Challenger
Re: E-body power brake linkage repop available? [Re: jrwoodjoe] #84683
07/06/08 09:15 PM
07/06/08 09:15 PM
Long Island NY
ErikR Offline OP
ErikR  Offline OP
Long Island NY
Cool, thanks Joe. I'll have to do some more digging around to make sure I get the right one before I spend the cash. I'm need it for a 70 barracuda and I'm using the power booster from a 71.
Do you have pic of the one that wound up working for you?
Re: E-body power brake linkage repop available? [Re: ErikR] #84684
07/07/08 08:27 AM
07/07/08 08:27 AM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
Yes, I haven't installed it yet but this is the one that will fit my car. My car was a 3 spd manual brake car. You can see that the shaft on one side is longer.
Joe
Re: E-body power brake linkage repop available? [Re: jrwoodjoe] #84685
07/07/08 08:29 AM
07/07/08 08:29 AM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
It's longer like the one in this photo posted by another board member.
Re: E-body power brake linkage repop available? [Re: jrwoodjoe] #84686
07/07/08 08:31 AM
07/07/08 08:31 AM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
This is like the one I bought first and does not fit correctly. You will notice the shaft is shorter. I could make this one work..(Rig it) but I'd rather it be correct so I'm using the other one. A friend of mine has a 72 RR automatic car with manual brakes and from the photos he sent me it looks like this one would fit it perfect.
Re: E-body power brake linkage repop available? [Re: jrwoodjoe] #84687
07/07/08 12:54 PM
07/07/08 12:54 PM
NORTHERN VA
THESHAKERPROJECT Offline
NORTHERN VA
The boosters had 2 different bearing I.D. One bigger than the other on the back that attaches to the linkage so make sure you have the rite one,
