help truck stuck and it keeps losing power #84503
07/05/08 06:26 PM
07/05/08 06:26 PM
Marion Illinois
72d100 Offline OP
72d100  Offline OP
Marion Illinois
every time my truck starts and i put it in drive it loses all power. any ideas, and its a 400 with electronic ignition
Re: help truck stuck and it keeps losing power [Re: 72d100] #84504
07/05/08 06:52 PM
07/05/08 06:52 PM
scratchnfotraction Offline
fusable link maybe
ballest resister
short in the wires
elect pick up in the dizzy
Re: help truck stuck and it keeps losing power [Re: scratchnfotraction] #84505
07/05/08 06:55 PM
07/05/08 06:55 PM
Richland , Webster County,Ga
Bubba C Offline
Bubba C  Offline
My 77 w-200 did that once and the wiring harness was rubbing through behind the distributer against the firewall...
Bubba
Re: help truck stuck and it keeps losing power [Re: 72d100] #84506
07/05/08 08:43 PM
07/05/08 08:43 PM
New Mexico
dmerc Offline
dmerc  Offline
New Mexico
What happens if you put it in reverse or nuetral?
Are you losing electrical power or does the engine just die with the indicator lights still on??
Re: help truck stuck and it keeps losing power [Re: dmerc] #84507
07/06/08 01:12 AM
07/06/08 01:12 AM
Marion Illinois
72d100 Offline OP
72d100  Offline OP
Marion Illinois
it only does it in drive and loses all electricl power
Re: help truck stuck and it keeps losing power [Re: 72d100] #84508
07/06/08 06:20 AM
07/06/08 06:20 AM
places
79powerwagon Offline
places
Check your engine mounts and your cab mounts. I've heard many a tale of SB trucks actually knocking the dizzy cap off from the cab rocking on bad mounts...
Re: help truck stuck and it keeps losing power [Re: 72d100] #84509
07/06/08 10:34 AM
07/06/08 10:34 AM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
little hard to knock the cap off.
does it just die (stall) or lose power? its starts back up right away?
Re: help truck stuck and it keeps losing power [Re: chrisf] #84510
07/06/08 11:41 AM
07/06/08 11:41 AM
Marion Illinois
72d100 Offline OP
72d100  Offline OP
Marion Illinois
i got it to grt power once so i started it, when i put it in drive it died and i aint had no power or anything since then.
Re: help truck stuck and it keeps losing power [Re: chrisf] #84511
07/06/08 02:04 PM
07/06/08 02:04 PM
Montana
P
Posest Offline
Posest  Offline
P
Montana
I have knocked the cap off before. You dont knock it all the way off you just bump it off center on the dizzy.
