Heater hose outlet on a small block waterpump #84494
07/05/08 04:59 PM
07/05/08 04:59 PM
Howell, Mi
Shatar4 Offline OP
Shatar4  Offline OP
Howell, Mi
I am not using the outlet on the waterpump for the heater but I have to block it off somehow. Has anyone ran into this problem and what did you do? Thanks
Re: Heater hose outlet on a small block waterpump [Re: Shatar4] #84495
07/05/08 05:12 PM
07/05/08 05:12 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
You can get caps for them at the parts stores, I cut the hose off and put a pipe plug in it and clamped it, guys have also tapped them for a pipe plug.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: Heater hose outlet on a small block waterpump [Re: MoparforLife] #84496
07/05/08 05:22 PM
07/05/08 05:22 PM
Howell, Mi
Shatar4 Offline OP
Shatar4  Offline OP
Howell, Mi
Any idea what size tap they used?
Re: Heater hose outlet on a small block waterpump [Re: Shatar4] #84497
07/05/08 06:53 PM
07/05/08 06:53 PM
Pizza Bucket
snuggles Offline
snuggles  Offline
Pizza Bucket
Re: Heater hose outlet on a small block waterpump [Re: snuggles] #84498
07/05/08 06:55 PM
07/05/08 06:55 PM
Howell, Mi
Shatar4 Offline OP
Shatar4  Offline OP
Howell, Mi
Nice pics but still doesn't tell me the size.
Re: Heater hose outlet on a small block waterpump [Re: Shatar4] #84499
07/05/08 06:56 PM
07/05/08 06:56 PM
Pizza Bucket
snuggles Offline
snuggles  Offline
Pizza Bucket
OOps I noticed no size listed after I posted
Re: Heater hose outlet on a small block waterpump [Re: snuggles] #84500
07/05/08 07:06 PM
07/05/08 07:06 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Measure the inside diameter of the bung and go from there. I'd guess 5/8" as that's the I.D. of the larger hose.
Re: Heater hose outlet on a small block waterpump [Re: In_The_Pink] #84501
07/05/08 11:07 PM
07/05/08 11:07 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
Its 3/8 NPT into the water pump. At least for a '69 water pump it is.
Re: Heater hose outlet on a small block waterpump [Re: 69Cuda340S] #84502
07/05/08 11:54 PM
07/05/08 11:54 PM
petaluma,ca. u.s.a.
west Offline
west  Offline
petaluma,ca. u.s.a.
napa would only sell me a box full
pm me with your address and i'll send you one for free
