Re: Radiator Size for a 440
[Re: 440_ci]
#84338
07/05/08 02:00 PM
07/05/08 02:00 PM
A buddy of mine has a '69 Charger. He contacted U.S Radiator www.usradiator.com They make a 4 core with all the factory dimensions and looks of the 22" and 26" rads. His car never gets hot even when sitting in the Carlisle traffic. I haven't looked into it much yet as my Dart never needed one. I recently acquired a '70 Charger with a 440. The guy gave me 3 extra rads because he said the car always overheated. So now I'll have to check usrad myself.
[Re: 440_ci]
#84340
07/06/08 09:50 PM
07/06/08 09:50 PM
Posts: 4,732 Watertown, WI
MikeyT
Watertown, WI
The difference between 22 or 26 isn't the point. Its how many cores you have in it. My older 440 engine in my Coronet would run fine on a two core 22" Radiator, but when I rebuilt my 440. I needed to recore my radiator into a three core one. I don't have issues with heating at all
Mike
1969 Dodge Dart Swinger
[Re: 440_ci]
#84342
07/08/08 07:52 PM
07/08/08 07:52 PM
Posts: 21,818 Kirkland, Washington
Pacnorthcuda
Well its a older stock 440 so it should be fine with my current 22inch rad ?
I run a mild-build 440 with a 22 inch rad--as do THOUSANDS of others. I do think the system has to be in good shape. Rad must flow well, you want a high flow stat, spring in the lower hose, no underdrive pulleys,fan shroud, GOOD fan, rad support/hood seal. It should be OK.
