Wiring dual 2-speed electric fans, do I need 2 relays?
#84322
07/05/08 11:22 AM
07/05/08 11:22 AM
Posts: 8,144 Arkansas
340727dart
Arkansas
I am in the process of mounting a dual 2-speed electric fan set up on my Dart. The fans run together on low and high. Do I need two 4-pole relays, or can I use one 5-pole relay, to switch between low and high?
Your life is not my fault. My life is none of your business.
Speech is free only if you agree with those in control.
Re: Wiring dual 2-speed electric fans, do I need 2 relays?
[Re: 340727dart]
#84323
07/05/08 12:15 PM
07/05/08 12:15 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Hmm, you'll need two relays unless you want it to run all the time on low speed.
