Re: NORMAL COMPRESSION???
[Re: polyspheric]
#841591
10/30/10 12:36 PM
10/30/10 12:36 PM
Posts: 4,311 Prospect, PA
BSB67
Prospect, PA
...out the exhaust valve" ???????
Which cam is that where the exhaust valve is open during the compression stroke?
I think you failed to understand my post. Obvously none, that's why there are the question marks. I'm quoting the other poster.
[Re: BSB67]
#841592
10/30/10 05:09 PM
10/30/10 05:09 PM
Posts: 4,206 New York
polyspheric
New York
You're right, sorry, yes I understood your comment to mean "Whaaaa?". Was referring to prior comment.
Boffin Emeritus
[Re: polyspheric]
#841593
10/30/10 05:24 PM
10/30/10 05:24 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
But, FWIW, the Calulater that Dodgem posted was Happy about by 20# PSI for my Combo. But with your engine specs, it was almost right on. mike it's not even close for my motor and as stated my leak down is less than 3% so I know it is sealed up well I also know someone that there roundy round motor is well over 600hp and only 165 cranking compression.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: dusturbd340W5]
#841594
10/30/10 05:34 PM
10/30/10 05:34 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
I run a big overlap pump gas cam, I get 150 cranking compression. I put one gallon of 110 race gas in the tank when I race but don't need to. I've used lawn mower gas to drive to a local car show before, and still goes 9.80's. If I go E85 this winter, it will get a better cam for performance.
[Re: Labratt]
#841595
10/30/10 05:44 PM
10/30/10 05:44 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
BTW...how important is it to have the butterflies partially open,as Hardcore suggests?
LABRATT, I feel it's very important. With the throttle closed can cause a restriction and produce lower than normal cranking compression readings
My personal preferance is to set the carb @ WOT when testing. Usually I'll hold it open with a wire or use the return spring to hold it FWIW.
Don't forget to return the throttle closed before you start the motor again
[Re: Dodgem]
#841597
10/30/10 08:52 PM
10/30/10 08:52 PM
dusturbd340W5
Kissimmee Fl.
yep carb wide open or removed and all 8 plugs removed and a battery charger hokked up and running is how I do it.
[Re: polyspheric]
#841598
10/30/10 09:05 PM
10/30/10 09:05 PM
Posts: 1,200 UK
602heavy
UK
large overlap cams bleeding compression
How exactly does this happen?
My thoughts exactly , overlap has no bearing on compression whatsoever.
