Re: WHAR'S UP...SPEEDO DOESN'T WORK, WON'T SHIFT. PLUS
[Re: eds dart]
#83967
07/04/08 01:57 PM
07/04/08 01:57 PM
Posts: 799 Missouri
bb74swngr
mopar addict
mopar addict
Missouri
You'll find two sensors on the transmission. One of them is bad. Had this happen to me. It was a PITB to get to them but it WILL fix your problem.
Russ:)
BigBlock 74 Swinger
Re: WHAR'S UP...SPEEDO DOESN'T WORK, WON'T SHIFT. PLUS MORE
[Re: eds dart]
#83971
07/04/08 04:16 PM
07/04/08 04:16 PM
Posts: 10,640 S.E.Ohio
Magnumguy
S.E.Ohio
Daughter's 96 Neon was shifting funny, noticed when it did the speedo was all over the place, checked the sensor, it was loose, and greasy.
Unhooked it, and cleaned it, no trouble since, 2 years ago.
It was on the back side of the tranny on her Neon, if I recall correctly. If it was here, I'd take a picture and make sure where it was.
[Re: GarageDodge]
#83973
07/04/08 10:34 PM
07/04/08 10:34 PM
Posts: 2,099 Central, NY
DanMcG
Central, NY
not sure if you have the same tranny but this might give ya an Idea of what you're looking for;
Re: WHAT'S UP...SPEEDO DOESN'T WORK, WON'T SHIFT. PLUS MORE
[Re: 6pkaar]
#83975
07/06/08 02:56 PM
07/06/08 02:56 PM
DanMcG
Central, NY
