Steering Column Shaft Lengths(Power vs. Manual) #83744
07/03/08 10:53 PM
07/03/08 10:53 PM
Great White North
71Furious Offline OP
super street
super street
Great White North
I have a couple of steering columns in the shop and I was wondering if anyone might know the shaft length differences(in inches)between power and manual equipped units. Any help would be appreciated and thanks in advance!!
Re: Steering Column Shaft Lengths(Power vs. Manual) [Re: 71Furious] #83745
07/04/08 09:12 AM
07/04/08 09:12 AM
michigan
440whiteboy Offline
440whiteboy  Offline
michigan
I think the manaul is apx. 15" from the firewall flange on the steering column -
power steering one is shorter maybe 12"
I might be off with the #'s but you should get the idea -
Another thing is I had an steering column to use with an automatic on the column - that had the right lenght, but the shaft had the inside steel tube with the lever for the kickdown was in the way for me. I'm not using it with my cable shifter - So I had to change it out because the shaft was rubbing on that tube for my manaul box.
They only see Stars...
when hit by a Mopar!
Re: Steering Column Shaft Lengths(Power vs. Manual) [Re: 71Furious] #83746
07/04/08 09:55 AM
07/04/08 09:55 AM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
Considering two columns fit the same model, PS shaft will be 3" shorter than a MS.
