6-Hemi Ignition Controller for 5.7L Hemi and tune? #83493
07/03/08 01:28 PM
07/03/08 01:28 PM
Anonymous OP
Anonymous OP
As far as I can tell theres the 6-Hemi Ignition Controller and the XV controler, They look the same, but the MSD controler is $50 cheaper.
What contronlers are you guys useing and why?
Did anyone buy a controler with out a tune in it? How hard was it to put a base tune, just to get the car running?
I have a 07 5.7L hemi with coil on plug, which wire harners do I need? Thanks Mike
Re: 6-Hemi Ignition Controller for 5.7L Hemi and tune? #83494
07/03/08 10:52 PM
07/03/08 10:52 PM
Tampa FL
hemibeep Offline
hemibeep  Offline
Tampa FL
I went to MSD website and they have the two wiring harnesses you need. I thought I read they have a base program that can be changed with a laptop. I do not think they use O2, so air/fuel may be hard to adjust. I think the programming is just for rev limit, start retard, and timing....not 100% though.
I am going to use this soon for my own project, anyone with experience. please chime in...
Re: 6-Hemi Ignition Controller for 5.7L Hemi and tune? [Re: hemibeep] #83495
07/04/08 06:44 AM
07/04/08 06:44 AM
houston texas
gremlinsteve Offline
houston texas
mike.
just bring it y the shop and have james tune it. you know thats the only real way here. run it on the dyno. its not that expensive.
steve
if You Like Gremlinsteve. Gremlinsteve Likes You.
