Challenger dash frame???? #83289
07/02/08 11:33 PM
07/02/08 11:33 PM
Odessa, Tejas
ChallengerRTSE Offline OP
Odessa, Tejas
Is there a difference in dash frames from 70 to 74? If so how do you tell a 70 dash frame frome the others?
Re: Challenger dash frame???? [Re: ChallengerRTSE] #83290
07/03/08 06:54 AM
07/03/08 06:54 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Pretty much the same frame for 70-4, a/c or non-a/c, Rallye or non-Rallye.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Challenger dash frame???? [Re: moparmarks] #83291
07/03/08 08:46 AM
07/03/08 08:46 AM
cataclysm80 Offline
cataclysm80  Offline
4 speed cars will have a hole for the reverse light, but you could weld it up if you dont need it.
Beep Beep said there was a difference in the 74 dash frame, but He wouldn't say what it is, so ???
Tav
Re: Challenger dash frame???? [Re: cataclysm80] #83292
07/03/08 09:29 AM
07/03/08 09:29 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Tav
Maybe the 74 has a couple mounting holes for the seat belt interlock modules? Otherwise I think there all the same except for the reverse lights for 4 speeds and that is for only 70-71? Did 73-74 4 speeds have the backup light???
Re: Challenger dash frame???? [Re: Challenger 1] #83293
07/06/08 11:03 PM
07/06/08 11:03 PM
restos just aren't my thing
gtsuperbee Offline
gtsuperbee  Offline
some 74 cars had a seat belt light that looked similar to a 4spd reverse light.
Restoring a car to look "only" as good as the factory made it is like getting a boob job for your wife and having the doctor make them two different sizes to seem more natural
Re: Challenger dash frame???? [Re: gtsuperbee] #83294
07/07/08 03:46 PM
07/07/08 03:46 PM
cataclysm80 Offline
cataclysm80  Offline
All the E body 4 speeds came with the backup light. The location of its mounting hole moved slightly between 1971 & 1972.
Although some other 74 mopars had a dash mounted seatbelt light, You should not find one on any 72-74 E body because those E bodies have the seat belt light located with the guages.
Tav
Re: Challenger dash frame???? [Re: Challenger 1] #83295
07/07/08 03:48 PM
07/07/08 03:48 PM
cataclysm80 Offline
cataclysm80  Offline
I'm interested in hearing any other suggestions as to what the difference is. Someone thought maybe the glove box used cables instead of that curved metal arm.
Any pics of that seat belt interlock stuff??
Tav
Re: Challenger dash frame???? [Re: cataclysm80] #83296
07/07/08 04:32 PM
07/07/08 04:32 PM
canaan ct usa
moparclown Offline
moparclown  Offline
canaan ct usa
I might be wrong but I thought 70-71 had attaching holes for the shaker cables.I do have 2-70 frames a 71 and 2-72 frames,but all are in storage right now.
Re: Challenger dash frame???? [Re: moparclown] #83297
07/08/08 04:55 PM
07/08/08 04:55 PM
cataclysm80 Offline
cataclysm80  Offline
shaker cable attaches under the bottom edge right? like the vent cables on non AC cars, the map light, the key buzzer, the road lamp switch on rallye dash 'cudas, and the long plastic AC trim piece. There are lots of holes pre drilled down there for things.
Tav
