Window regulators??? #832144
10/17/10 05:53 PM
10/17/10 05:53 PM
St.Louis,Mo.
70RR383 Offline OP
70RR383  Offline OP
St.Louis,Mo.
I have a 70 RR with power windows,What would inter-change??69 charger non-power??Are power and non -power the same??Thanks
Re: Window regulators??? [Re: 70RR383] #832145
10/17/10 06:00 PM
10/17/10 06:00 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Whats wrong with the regulator you have...
Power vs manual are different.. hardtop vs vert are different...
But if you have the correct regulator even though is has a problem it should be repairable...
Re: Window regulators??? [Re: 1_WILD_RT] #832146
10/17/10 06:29 PM
10/17/10 06:29 PM
St.Louis,Mo.
70RR383 Offline OP
70RR383  Offline OP
St.Louis,Mo.
I have not tore into it yet.When I try to roll it up or down it SKIPS like there is teeth missing.I have never worked on one.
Re: Window regulators??? [Re: 70RR383] #832147
10/17/10 06:40 PM
10/17/10 06:40 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
That may well be the motor, inside the drive gear there are three rubber drive lugs that compress & eventually fail... Instead of the window moving the motor runs & you get a thud thud thud sound... It will do that anywhere in the windows range of travel... If it only does it at the very end of the travel than the teeth on the regulator are likely damaged & the fix is to grab a power window regulator from some other mopar at the junkyard, C bodies, F bodies, M bodies it doesn't matter.. The gear is the same, the mounting plate is also the same... The arms & such are different but you can cut the head off the rivet & save the gear from the J/Y regulator & swap it into your regulator saving all the other original pieces... As you can't duplicate the original jumbo rivet I have just welded a bead onto the original rivet & had no issues with the repair...
Re: Window regulators??? [Re: 1_WILD_RT] #832148
10/17/10 07:24 PM
10/17/10 07:24 PM
St.Louis,Mo.
70RR383 Offline OP
70RR383  Offline OP
St.Louis,Mo.
Thanks,I have bought some motors over the years.I will tear into this winter.Thanks for the info.
