PS hose leaking #83086
07/02/08 03:03 PM
07/02/08 03:03 PM
Sweden
Forssling Offline OP
Sweden
Hi All.
I just put in a new steering gear from Steer and Gear and it feels really good.
But I've got a small leak on the top of the steering box where the inlet hose goes on.
I have tightened it as much as I dare but there is still a leak. Is there some tape to put on the threads that is heat resistant? Or do you guys have another suggestion? Should I just try to tighten it some more? I'm afraid I'll break something.
Thanks for any input.
Jörgen Forssling Göteborg, Sweden 1970 Cuda 340
Re: PS hose leaking [Re: Forssling] #83087
07/02/08 03:06 PM
07/02/08 03:06 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
That's a compression fitting (like brake fittings) so no sealing tape will help, If it's that tight I'd take it apart and inspect the sealing surfaces for nicks, etc....If they look ok tighen some more.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: PS hose leaking [Re: HemiRick] #83088
07/02/08 05:00 PM
07/02/08 05:00 PM
toronto canada
69chargeryeehaa Offline
toronto canada
i agree, it's a compression fitting, try loosening it, then tightening it just enough so you can move the hose back and fourth a few times, then tighten it....that works for me sometimes....
Re: PS hose leaking [Re: 69chargeryeehaa] #83089
07/03/08 04:33 PM
07/03/08 04:33 PM
Sweden
Sweden
Thanks guys. I'll check the fitting tomorrow. Now it's bedtime over here in Sweden.
