915 heads ? #83027
07/02/08 11:39 AM
07/02/08 11:39 AM
CA
66Dodge Offline OP
super gas
66Dodge  Offline OP
super gas
CA
I bought a set of newly rebuilt 915 heads off eBay many years back and hadn't gotten around to them until now.
I just measured the exhaust valves and found they are 1.60" !
I thought all 915's were the onetime castings used in the '67 HP 440's and had the 1.74" exhaust valves ?
I guess I'll have my machinist install the bigger valves.
Despite the smaller exhaust valves that came with these heads, are the ports still the better flowing ones ?
Thanks in advance.
Re: 915 heads ? [Re: 66Dodge] #83028
07/02/08 11:42 AM
07/02/08 11:42 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
I had a set of 160 ex 915's, they are out there, pretty common. I had the seats opened up to 181's and I believe the port configuration to be same as 906's.
Re: 915 heads ? [Re: buildanother] #83029
07/02/08 12:08 PM
07/02/08 12:08 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
They have the good ports, i have a set on my near stock 383 68RR , i just did bowl work left the stock 160's in and had all the valves backcut, thats what my engine builder recomended for a stock 383 he said their would be very little difference in going bigger, but in my opinion if you are going to build even a mild performance motor i would at least go with a set of 1.74
Re: 915 heads ? [Re: ademon] #83030
07/02/08 12:29 PM
07/02/08 12:29 PM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
Mine had those 1.60's and now they have the 2.14/1.84's.
Moparlee
Re: 915 heads ? [Re: 66Dodge] #83031
07/02/08 01:03 PM
07/02/08 01:03 PM
Jersey shore
Gary67 Offline
super street
Gary67  Offline
super street
Jersey shore
I boughThe factory stamped hp 915s had the large valves the non hp had the small same head other than that...t a set of newly rebuilt 915 heads off eBay many years back and hadn't gotten around to them until now.
Thanks in advance.
The hp stamped 915 heads had the large valves no hp stamp had the small ones, same head otherwise...
Re: 915 heads ? [Re: Gary67] #83032
07/02/08 01:15 PM
07/02/08 01:15 PM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
Really, I thought that there were three 915 heads out there if you will. The small exhaust valve and the big exhaust valve heads and then there were HP's and of course those had the big valves?
Moparlee
Re: 915 heads ? [Re: Robbins] #83033
07/02/08 01:23 PM
07/02/08 01:23 PM
Jersey shore
Gary67 Offline
super street
Gary67  Offline
super street
Jersey shore
Just two far as I know, it was the first bb head with the 1.74 exh valve I think also....
Re: 915 heads ? [Re: Robbins] #83034
07/02/08 01:27 PM
07/02/08 01:27 PM
NY usa
540challenger Offline
NY usa
There are 3 versions on the 915 "J" heads in the smal block world.
Big intake 2.02
Small inake 1.88
And then the T/A heads with the big intakes with the off-sets pushrods.
Re: 915 heads ? [Re: 540challenger] #83035
07/02/08 01:30 PM
07/02/08 01:30 PM
Jersey shore
Gary67 Offline
super street
Gary67  Offline
super street
Jersey shore
I was refferring to the BB 915s.....
Re: 915 heads ? [Re: Gary67] #83036
07/02/08 01:36 PM
07/02/08 01:36 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
It was the second. The '63 383-343hp 2x4bbl motor used a 1.74 exh valve. I think the '62-'64 300 letter cars also used a 1.74 exh.
There were more 1.60 exh 915s than there were 1.74. I've had two pair over the years.
Re: 915 heads ? [Re: B5 Bee] #83037
07/02/08 01:42 PM
07/02/08 01:42 PM
Jersey shore
Gary67 Offline
super street
Gary67  Offline
super street
Jersey shore
Interesting, I think some leftover small valve BB 915s made it to some 68 models..Think the smallblock 915 was 69/70 or around there...
Re: 915 heads ? [Re: Gary67] #83038
07/02/08 01:58 PM
07/02/08 01:58 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
The SB 915 first appeared in '70 on 340-4 and 340-6.
Re: 915 heads ? [Re: Gary67] #83039
07/02/08 03:03 PM
07/02/08 03:03 PM
CA
66Dodge Offline OP
super gas
66Dodge  Offline OP
super gas
CA
Thanks in advance.
All these mopar books and magazines refer to the 915 heads as the high performance head back in in 1967. Of course this leads one to believe there was only one variant with the larger exh. valve.
No one ever mentioned there were 915 heads with the 1.60" valve. These were probably used in land barges with 440 low performance engines.
