The speedo in may 1972 Coronet is not working. I've tried a few things and can't seem to find the problem. Here's what I've done so far, maybe someone has an idea for me?
1. I removed the cable at the gauge and drove the car with the end out where I could see it. The end of the cable was not rotating so that means it's a problem at the trans.
2. Removed the cable from the trans and it rotates fine by hand.
3. Pulled the speedo gear, no teeth missing.
4. I thought maybe I had rotated the speedo gear away from the gear it mates to in the tail shaft. So I reinstalled it and rotated it to where I felt it should mess. Hooked the cable back up and drove it. Still doesn't work.
Any ideas?
