carter,edelbrock #83016
07/02/08 10:23 AM
07/02/08 10:23 AM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
i just bought a 1977 ply,it has a 360 in it ,the accel. pump was not working so i took the carb off and its an edelbrock but looks like a carter thermo.there are no #s on the carb body anywhere but i did find a tag with 1905 d 215 26 on it. icant find anything on line about this carb and where to get parts. so any help would be great.thanks,AJ p.s. im not adverse to changing over to a holley if a bolt on replacement is avail.
Re: carter,edelbrock [Re: bonefish] #83017
07/02/08 10:58 AM
07/02/08 10:58 AM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
Black plastic bowl? The number is on the driver side rear on the throttle plate. Edelbrock never made these carb. Out of production since 84 or 85.
Should start with 6 or a 9. If it is a TQ.
AFB's, "Carterbrocks" and AVS's are marked on the front passenger side throttle plate.
Did they put out the fire in Golden Gate Estates yet?
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: carter,edelbrock [Re: Rug_Trucker] #83018
07/02/08 11:24 AM
07/02/08 11:24 AM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
the carb has an edelbrock badge on it,its all metal,there is a boss where a # sould be but there is none,unless it got wore smooth.
