Okay, so we are putting wilwood brakes on a 70 Dart Swinger. The K member is out of the car and been rejuvenated with new hardware, steering gear and suspension. The only real question is: What steel braided brake hose are you folks running on this type of setup?
I am thinking that the AN 4 steel braided hose with about 15 inches of length is whats needed & a decision on one end being 90 degree or both straight, but I would hope that some of you folks have pointers to offer on this situation. The rest of the info is the K member is late model with spool type mounts and a 451 is going together coupled with a 4 speed and 8-3/4 Suregrip in about a 4:10 gear range to drive the body. Thanks for your help.
doc
