Who is running a Lakewood Bell in a BB B-body ? #82951
07/02/08 12:23 AM
07/02/08 12:23 AM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
I'm trying to figure out what sort of linkage issues I will have with my Lakewood. I've got a used Lakewood blowproof bellhousing that was in feets Belvedere. It has a stud mounted to the side of it, but I can't figure out what I need for a clutch fork with my 10.5" Clutch set up.
Do can I use the correct one for an iron bellhousing or do I need another fork?
Also, how will the bellhousing and linkage clear with headers on my car ?
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: Who is running a Lakewood Bell in a BB B-body ? [Re: AlexP] #82952
07/02/08 12:47 AM
07/02/08 12:47 AM
Eastern North Carolina
cyphre666 Offline
cyphre666  Offline
I put one in a 68 GTX.
Linakage is the same.
I did have to trim the bellhousing on the r/s
to clear the headders.
That was with a set of 2 1/8 TTI's.
Re: Who is running a Lakewood Bell in a BB B-body ? [Re: cyphre666] #82953
07/02/08 02:27 AM
07/02/08 02:27 AM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
Thats what I needed to hear. I will be running Hooker 5903's on my car this time around.
Re: Who is running a Lakewood Bell in a BB B-body ? [Re: AlexP] #82954
07/02/08 11:42 PM
07/02/08 11:42 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I used the stock clutch fork with mine.
Be sure you've got the starter adaptor set up for the 10.5" clutch.
- Stu Harmon
