Re: Pressure plates: how much is too much ?
[Re: DAYCLONA]
#82944
07/02/08 11:04 AM
07/02/08 11:04 AM
Posts: 74,974 U.S.S.A.
JohnRR
U.S.S.A.
I think it comes down to how much of a "man" are you,.......some guys complain about 2200 lbs!......I've been running a 3400 lb BorgBeck design in my Challenger T/A for the last 15 years,.....someguys can't even squeeze the pedal down on it.....they think I'm ......but I like it because the "hook-up" is awesome......but you have to beef up all the linkage system,....otherwise things start to shear!
My Daytona on the other hand has a Keisler TKO 5spd with a hydualic throwout w/ a 2800 lb Sachs B/B style......the pedal effort is almost non-exsistant.......the hydualic set up is nice, although you lose the "feel" that a "real" pedal gives you!.......I think your focus is best aimed at what your driveline needs are, what are the intended uses of the car,.....there are many set-ups to address any need?......so there's a lot of variables to your question,......everyones gonna have a different opinion on what to run?
[Re: DAYCLONA]
#82947
07/02/08 12:02 PM
07/02/08 12:02 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Pedal can be gotten used to. I switched from power brakes to a big bore manual brake setup, thought about switching to something else after it first got in. Pedal doesn't seem even 'firm' anymore...you'll get used to it.
[Re: AlexP]
#82950
07/02/08 05:10 PM
07/02/08 05:10 PM
Posts: 5,788 Hamilton, Ontario Canada
Magnum
If you are looking for decent clamping force without the big pedal pressure, look into a Centerforce.
