How do I reset the brake light? #82701
07/01/08 02:04 PM
07/01/08 02:04 PM
a cornfield near you
BlakDak Offline OP
BlakDak  Offline OP
on a 1993 Dakota?
It has rear abs, I have pulled the battery cable, and its still comes back on.
Abs works, the brakes are bled....and work fine.
it all started when I blew a wheel cylinder
thanx
Re: How do I reset the brake light? [Re: BlakDak] #82702
07/01/08 04:51 PM
07/01/08 04:51 PM
BlakDak Offline OP
BlakDak  Offline OP
bump.... I can get it to go out for a short while......but as soon as I "back" out of the drive it comes on.
I shut it off in the street, and started it back up, and it never came on again, until I went into reverse...:(
the speed sensor going out?
Re: How do I reset the brake light? [Re: BlakDak] #82703
07/01/08 06:21 PM
07/01/08 06:21 PM
cincinnati ohio
mcat4321 Offline
mcat4321  Offline
cincinnati ohio
try un hooking both battery terminals wait 30 sec. touch both terms together. that might do it
Re: How do I reset the brake light? [Re: BlakDak] #82704
07/01/08 07:35 PM
07/01/08 07:35 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Since the problem started when the wheel cylinder failed, I would suspect the pressure differential switch in the combination valve.
Re: How do I reset the brake light? [Re: John_Kunkel] #82705
07/01/08 08:17 PM
07/01/08 08:17 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Try hitting the brakes hard while stopped. It might recenter the warning switch.
Re: How do I reset the brake light? [Re: John_Kunkel] #82706
07/01/08 08:30 PM
07/01/08 08:30 PM
BlakDak Offline OP
BlakDak  Offline OP
is this the single pin sensor?
Re: How do I reset the brake light? [Re: BlakDak] #82707
07/02/08 10:36 AM
07/02/08 10:36 AM
BlakDak Offline OP
BlakDak  Offline OP
any one else?
Re: How do I reset the brake light? [Re: BlakDak] #82708
07/02/08 10:45 AM
07/02/08 10:45 AM
NH
72challorange Offline
He's Game
He's Game
NH
I think the sensor on the top of the rear diff is prone to failing.
Try this site for more info.
Tom
http://www.dodgedakotas.com/boards/dea/168.html
Re: How do I reset the brake light? [Re: 72challorange] #82709
07/02/08 12:54 PM
07/02/08 12:54 PM
beepilot Offline
beepilot  Offline
Not sure about a Mopar but on my daughters 98 Lumina, pulling all the fuses for ABS/Brakes and pushing the brake pedal a few times and waiting a few minutes worked every time. Seems there is residual power you have to drain to reset the idiot lights. Unhooking battery might do the same as pulling fuses but for me with the battery buried pulling fuses was easier.
Re: How do I reset the brake light? [Re: beepilot] #82710
07/02/08 01:00 PM
07/02/08 01:00 PM
NY usa
540challenger Offline
NY usa
On some cars I have had to keep the battery disconted for almost a hour to get the lights to go off.
