throttle cable bracket identification? #82678
07/01/08 01:29 PM
07/01/08 01:29 PM
Anonymous OP
Anonymous OP
Picture is of 3 different throttle cable brackets: The one is for B/RB; second one fits a small block intake; third one fits on the back two holes of a small block intake. Is there a difference between 2bbl and 4bbl brackets?
Re: throttle cable bracket identification? #82679
07/01/08 01:36 PM
07/01/08 01:36 PM
Pizza Bucket
snuggles Offline
snuggles  Offline
Pizza Bucket
I believe the 4 bbl retaining nuts thread from the side instead of downward
Re: throttle cable bracket identification? #82680
07/01/08 01:49 PM
07/01/08 01:49 PM
Anonymous OP
Anonymous OP
I guess another question would be why the difference in location between the 2 small block brackets? Year difference? 2 or 4 bbl difference?
Re: throttle cable bracket identification? #82681
07/01/08 09:22 PM
07/01/08 09:22 PM
Anonymous OP
Anonymous OP
Re: throttle cable bracket identification? #82682
07/01/08 09:45 PM
07/01/08 09:45 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I'm not gonna be much help, bu there are differences between 4 barrer versus 2 on all engines. But what applications you have shown I have no idea, than the obviously small block one to the far right
Re: throttle cable bracket identification? [Re: gtx6970] #82683
07/01/08 10:00 PM
07/01/08 10:00 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
318 small block on the right, 360 small block in the middle.
I removed this from a '79 360 2-bbl in a Magnum:
And this one from a 318 2-bbl in a '79 Volare Duster:
I haven't found a 360 4-bbl bracket...yet.
I would think 2-bbl and 4-bbl brackets are different, due to the narrower width of a 2-bbl carb. I had to modify a 2-bbl bracket to get a good approach angle on the throttle lever with the factory throtle cable.
Re: throttle cable bracket identification? [Re: In_The_Pink] #82684
07/01/08 10:10 PM
07/01/08 10:10 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
as far as I know LA motor brackets are all the same if 4 barrel equipped
Re: throttle cable bracket identification? [Re: gtx6970] #82685
07/01/08 10:23 PM
07/01/08 10:23 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Thanks for posting that, Bill.
Now I know what to for.
Re: throttle cable bracket identification? [Re: gtx6970] #82686
07/02/08 08:55 AM
07/02/08 08:55 AM
Pizza Bucket
snuggles Offline
snuggles  Offline
Pizza Bucket
Thats the one I attempted to describe
Re: throttle cable bracket identification? [Re: snuggles] #82687
07/02/08 09:05 AM
07/02/08 09:05 AM
Pizza Bucket
snuggles Offline
snuggles  Offline
Pizza Bucket
heres one thats a little different I think mid 80s was what I got it from
Re: throttle cable bracket identification? [Re: snuggles] #82688
07/02/08 11:02 PM
07/02/08 11:02 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
That appears to be a 2-bbl bracket with dual clamps for the throttle and speed control cables.
Re: throttle cable bracket identification? #82689
07/03/08 01:17 AM
07/03/08 01:17 AM
near Harrisburg, Pa
440trk Offline
440trk  Offline
near Harrisburg, Pa
Most certainly is a difference. The 2v mounts will have the throttle cable clamp farther rearward than the 4v ones.
Look at where a 2v throttle linkage (on the carb) sits in relation to the rear of the engine. Then look at a 4v setup. Because a 4v carb has the throttle linkage farther forward on the physical carb, Mopar used a throttle cable bracket that also moved the mounting point for the throttle cable forward as well.
Clear as mud? If I get a chance this weekend, I'll see if I can show ya what I'm talking about.
