Re: 440 throttle cable question
[Re: 69chargeryeehaa]
#82505
07/01/08 10:48 PM
07/01/08 10:48 PM
Posts: 3,319 Chicago Burbs
sthemi
Chicago Burbs
you could try adjusting the cable on the kick down linkage mount, just undo the 7/16" nut and pull the cable away from the carb, this will bring the pedal up.
The pedal height is controlled by the distance of the outer shell in relation to the inner cable that hooks to the carb. Slide it back for more height, be sure you are getting full throttle opening on the carb when you are done.
[Re: sthemi]
#82506
07/02/08 10:42 AM
07/02/08 10:42 AM
Posts: 1,220 toronto canada
69chargeryeehaa
toronto canada
that's basically what i was trying to say...
