Re: Pros and Cons for 284/484 cam
[Re: VITC_GTX]
#82241
06/30/08 07:49 PM
06/30/08 07:49 PM
Posts: 390 pacific northwest
wings471
pacific northwest
I've read all of those ..opinions.. myself. I have that cam in a alum. head 383 with quality parts thru-out. The motor maybe makes 450-475 hp in a '68 Coronet Boat. I had a low stall converter which made the car unfun to drive. I called Andre @ Edge racing converters and gave him the specifics. He built a 3000 stall for me. It's great from a dead stop and it is civilized in traffic. For a boat it is surprising how strong that combo is and it just keeps pulling. Before with the 2000 stall it was ugly from a dead stop. I like that cam with the correct converter I also run 3.55's with 29" tires.
[Re: mike s]
#82244
06/30/08 09:08 PM
06/30/08 09:08 PM
Running that cam in a 30 over 440 six pack motor 475-500 hp with a 2200 - 2400 stall converter and 410 gears and 29" tires and it is in a 3800 lb car and it is a hand full. Couldn't be more happpier with the set up.The only cam I ever ran in all my 440 motors
Thanks Moparts
[Re: VITC_GTX]
#82245
06/30/08 09:23 PM
06/30/08 09:23 PM
Posts: 16,453 Canada
CrAzYMoPaRGuY
Canada
Not sure who disliked them cam, but I sure like it. I've used it over a dozen times, I had the 484/284 P4120235 in my Demon, it not only performed VERY well it also passed our BC AirCare emissions testing with NO detuning whatsoever, WITH the engine exactly as you see it.... I've ran the cam in different compression ratio engines, 383 to 440s, so long as the engine is fairly good shape and decent compression with heads that flow decently I have always LIKED the MP 484 cam. There's ALWAYS a group that doesn't like a particular part, or a particular brand, etc etc...
CrAzYMoPaRGuY
[Re: CrAzYMoPaRGuY]
#82246
06/30/08 11:08 PM
06/30/08 11:08 PM
I have the same cam in my 383 powered '71 RR. Motor is about 10.25/1 compression, mild head work, 4:10 gears and 28 inch tall rear tires, it's a nice combo. BTW torque converter stalls around 2800-3k.
[Re: Mr.Yuck]
#82249
07/01/08 10:05 AM
07/01/08 10:05 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
I mentioned in a simular post, that the 284/484, and 292/509 purple shaft cams were designed for beacket racing. These were the cams of choice in the Mopar Performance catalogs if you were building a bracket race car (hi-stall converter, open headers, and 4.10+ gears.) The 108 lobe seperation angle tends to create a strong, but narrow torque curve in the mid to upper RPM range. Because of the increased overlap, the idle is choppy, vacuum is low, and low end torque is fairly weak below 2,500 RPM.
The newer "street performance" cams use a slightly wider lobe seperation angle and split intake/exhaust duration to provide a wider torque curve that will still perform good in the upper RPM range, but they may not have as much "peak" torque as the Mopar purple shaft cam.
[Re: 451Mopar]
#82250
07/01/08 11:17 AM
07/01/08 11:17 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
that's what I should have said..lol
[Re: Mr.Yuck]
#82251
07/01/08 12:23 PM
07/01/08 12:23 PM
CrAzYMoPaRGuY
Canada
They are poo poo dog cams. Unless you have a3k stall, 3.91's 10:1 (or better) good exhaust (headers)RPM intake (or like), good carb they are dog cams. They don't pull until 3k or better, make no power down low. If you have all the above they will work pretty good however they are not a good street cam. They have terible idle quality and pull zero vacuum.
Great assessment. Just not ACCURATE.
Have you ever actually ran a 484/284 in a car? Give us the specs on the engine.
I've ran a ton of them, my Demon had the P4120235...
LESS than 10.1 to 1 compression Pulled VERY good down low. (with a tunnel ram and 2x4bbl too) Made tons of low end power. Idled solid as a rock in neutral and in gear. EXTREMELY drivable, it was a great package. Pull "zero" vacuum? Get real, my Demon had POWER BRAKES, it never had a hard pedal in the 10 years I regularly drove it on the street.
The car was fairly well known as I had it out all the time, in the middle of winter in 6" of snow even. I drove it year round for close to a decade. My wife went shopping in it quite a bit.
Could it be you guys who don't like the MoPar Performance stuff are setting up your cars WRONG, then blaming the parts instead of the tuner..?
Take a look- 484/284, tunnel ram, two four barrels and it passed AirCare emissions testing without detuning at all every single year, from 1991 until 2000.
I raced alot of cars in that time in the lower mainland of B.C., ask around how poorly my combo worked, most people asked if the car was a roller cam, and we would all laugh.
CrAzYMoPaRGuY
[Re: Mr.Yuck]
#82253
07/01/08 12:34 PM
07/01/08 12:34 PM
CrAzYMoPaRGuY
Canada
My buddy's 9 to 1 440 with a 484/284 was a mild street driver too- he went 12.80 on the motor and 11.63 on a small bottle at Ashcroft. WITH 2.76 GEARS!!!!! And 29" tall slicks! He had power brakes too. I just wonder what the tuning was like in your cars, toss some specific parts etc at us and let's see if we can figure out where you guys went wrong or not...
CrAzYMoPaRGuY
[Re: CrAzYMoPaRGuY]
#82254
07/01/08 12:44 PM
07/01/08 12:44 PM
Mr.Yuck
Brookeville, Md
yes i have. Will the car run? sure it's a 440. last one was a67 coronet 9:1 440 906 heads with a little work, 2200 convert, headers, CH4B intake 750 Eddy car and 3.55's it was a DOOOOOOG. Put in a Summit 488 cam and it ran great. The old style 484's and 509's like to run form 3k up. I also had a 69 Charher w/ a stock 73 440 that somebody put a 509 in...doooog. Glad yours worked. what gear? what stall?
[Re: Mr.Yuck]
#82257
07/01/08 01:05 PM
07/01/08 01:05 PM
CrAzYMoPaRGuY
Canada
I've ran 484 and 509 cams in all sorts of cars personally, and most of my buddies have too. I've had over a dozen cars I put the cams in myself... Did you degree your cams or just install them stright up on the timing gears? (What timing gears? ) My buddy had the worst gearing IMO, he had 2.76 gears with 29" tall tires, it was a 63 Dodge that was known locally as "The Lobster". It ran 11.63 at 118mph at Ashcroft on a small powershot kit, he just barely got out of second gear. I have it on tape somewhere, the whole stands starts to laugh when the car's numbers came up on the board, they knew what was in the car. My wife's Cordoba was a 484 with a STOCK torque converter, she drove it every day. She could fry the tires at will. Most of my cars were steeper geared but taller tired, however I did run highway gears on a few of them, no problems. I ported the heads myself, degreed the cams myself, built the engines myself, and never had any issues with any of the cams. I've never seen any of my local Mopar buddies ever "complain" about the cams the way they are complained about in this thread, I'll have to show them this. We all had good bottom end power and all had good vacuum, the vast majority of the cars had power brakes too. Small pot reservoir power brakes to boot. A 1973 Charger was an 8.2 to 1 engine on PAPER, did you ever figure out the true compression ratio on what you were running? I'm willing to bet it wasn't what you thought! A 509 cam and a sub 8 to 1 compression engine that's not in great shape aren't exactly a "recipe for success" if ya know what I mean? Combine that combo with highway gears and a heavy car and for SURE the car SHOULD be a "dog", IMO anyways..?
CrAzYMoPaRGuY
[Re: kenworth_goose]
#82258
07/01/08 01:10 PM
07/01/08 01:10 PM
Mr.Yuck
Brookeville, Md
All I can say is if you had a doooog with a 484 or a 509 you had other issues. I've used many in both small blocks and big blocks with bone stock bottm ends and they screamed. The last was a 68 dart with a 508 stock bottom end, stock heads with a good intake carb ign etc. went 12.40's all day long in 90 degree heat and a stock convertor with 3.91's, with street tires and full exhaust. Maybe you need a new tuner?
yeah maybe small block what? comparing a small block to a big block is silly. Typically 340's don't starting running well until 2500-3000 rpm. So one of those cams would work better in a SB. You had 3.91's so you'll get to the rpms quicker. if you had 3.23's in the car it would have been a dog, also if you had a more modern split duration cam in the car it'd run better too. Would my 2 cars do cool burn-outs?? yeah but those cams weren't designed for mild street applications. Funny cam swap only dropped me over a 1/2 second and had much better throttle response and created a longer powerband. I had a well worked 383 in a 68 dart that I used a 509 in. That car ran great 11.80's but it was far from a mild street engine and the car had 4.30's and a bunch of other goodies.
