Looking at headers today for the 67 baracuda.
Options:
78' 360 motor with J-style heads.
4 speed w stock Z-bar and linkage.
Mini starter-no prob.
Kevko 6 quart pan, supposed to have no clearance issues.
Here's the kicker:
TTI's website says will not fit quick ratio steering pittman arm/ idler arm deal.
I ran it by Hedman and they said the same thing, plus the hedman would require me to grind some stuff on the Z-bar, and modify a shift linkage tab and bend a rod.
Do I have any options other than having a set fabbed up somewhere to clear stuff, or should I just bolt my old steering gear and pittman back on?
I wish I had a set of used headers to dry fit under there.
