Trouble with my 3.0 v6 LeBaron #82147
06/30/08 03:54 PM
06/30/08 03:54 PM
Winterville, Ga USA
rogue_leader007 Offline OP
Winterville, Ga USA
Alright, I'm a little baffled with this one. I know most q&a is about older mopars, but this one is my daily driver and I need it to commute to work.
Its a '90 LeBaron with a 3.0 OHC V6. It started to skip and sputter and jerk violently, and sometimes stall out when I'm going down the road.
I changed the oil and filter, spark plugs, wires, distributor cap and rotor button, PCV valve. The air filter is clean, and I recently had the catalytic converter cut off and replaced with straight pipe. The converter was nearly clogged. And where I live, emissions laws a practically nonexistant.
Still, no changes. Plus, it started sucking fuel like a small block. Also, when I to gun it, it starts losing power, and then leaps to a massive burst of speed.
Friends have told me it could be the coil, the oxygen sensor, or, at worst, the computer.
I'm getting tired of constantly spending money on this thing without results, and figured I see if anyone here would know anything before I decide to trade this thing in or sell it off.
Any help is appreciated.
Glad to be back in the hobby.
68 Plymouth Valiant
Re: Trouble with my 3.0 v6 LeBaron [Re: rogue_leader007] #82148
06/30/08 03:57 PM
06/30/08 03:57 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Check the fuel pressure when its acting up.
Re: Trouble with my 3.0 v6 LeBaron [Re: rogue_leader007] #82149
06/30/08 05:29 PM
06/30/08 05:29 PM
North Pole,New York
formula_s Offline
formula_s  Offline
North Pole,New York
Instead of throwing parts at it you should see if it has any codes.Easy enough to do. Key on off twice followed by key on,just count the flashes.You can interpet the code at allpar.com.
Re: Trouble with my 3.0 v6 LeBaron [Re: formula_s] #82150
06/30/08 06:19 PM
06/30/08 06:19 PM
Cookeville
Chilort Offline
Will Work For Mopars
Chilort  Offline
Cookeville
Once you've checked the codes, there are some great junk yards around here. Check out http://www.pullapart.com
I've been to both locations in Atlanta and the one in Augusta.
