Engine bolts sizes for SB #82065
06/30/08 10:45 AM
06/30/08 10:45 AM
Anonymous OP
Anonymous OP
Does anyone have a list (or know where to get a list) of bolt sizes to assemble a small block. I am trying to build one for a 70 cuda but I am missing some of the original bolts.
I have intake manifold, carb, head bolts, balancer, flexplate/TC, and main bearing bolts but I'm missing:
oil pump
oil pan
camshaft plate
timing chain cover and water pump
clutch fan
fuel pump
bell housing
starter
If anyone can post these, I would appreciate it.
Thanks in advance
Re: Engine bolts sizes for SB #82066
06/30/08 10:49 AM
06/30/08 10:49 AM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
Re: Engine bolts sizes for SB [Re: AdamR] #82067
06/30/08 11:04 AM
06/30/08 11:04 AM
Anonymous OP
Anonymous OP
Thanks!
I forgot to add, the engine to transimission bolts that I need are for a 727 (and not a stick)
Re: Engine bolts sizes for SB #82068
06/30/08 11:28 AM
06/30/08 11:28 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Bell housing bolts should be the same.
