Fender door alignment for 70 bbody #820542
10/03/10 03:00 AM
10/03/10 03:00 AM
GA
roy2345 Offline OP
roy2345  Offline OP
GA
How can I adjust clearance from door to fender without bothering door hinges? I need 1/4 inch more clearance. Which bolts adjusts fender?
Re: Fender door alignment for 70 bbody [Re: roy2345] #820543
10/03/10 12:46 PM
10/03/10 12:46 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
You're pretty much committed to loosening up the whole fender and pulling it forward to get the gap...That's mostly all of them.. ...Upper and lower cowl,rad support, inner fender bolts, etc... Try to move it as little as possible so you don't get into any hood alignment issues..
