ticking noise any ideas #82029
06/30/08 09:56 AM
06/30/08 09:56 AM
own private Idaho
N
ngpSatellite Offline OP
N
own private Idaho
Put together a 69 383hp std bore and I have ticking noise like a cricket coming from what sound like the exhaust by the manifold...when you rev the engine it sounds perfect and you can't really hear it when you open the hood but you can hear the noise in the cabin
Re: ticking noise any ideas [Re: ngpSatellite] #82030
06/30/08 10:57 AM
06/30/08 10:57 AM
IMGTX Offline
IMGTX  Offline
Sounds like an exhaust leak or a loose plug.
Sometimes if the oil pressure is low at idle a lifter may tap until the pressure spikes when the engine revs a little.
Re: ticking noise any ideas [Re: ngpSatellite] #82031
06/30/08 01:14 PM
06/30/08 01:14 PM
Riverside, Ca
R70RUNNER Offline
R70RUNNER  Offline
Riverside, Ca
Stock manifolds, rt side? Mine makes a slight tick, leaks by the weighted flapper at cold idle, once it warms up and things expand it's no issue.
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
