10.5" Clutch....what are you running ? #81947
06/30/08 02:00 AM
06/30/08 02:00 AM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
I want to order a clutch to go on a 10.5" flywheel behind my .484 cammed 383 with 3.91 SG in my Roadrunner. I want a seriously fun street car, moderate pedal pressure and good holding power when needed.
I've got a $30 off coupon from Summit and I can't make up my mind. I can't see any reason why I shouldn't get a Dual Friction and be done with it...
Any opinions before I put money down ?
Also, can anyone break down the different pressure plate styles along with their pro's and con's ?
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: 10.5" Clutch....what are you running ? [Re: AlexP] #81948
06/30/08 05:15 AM
06/30/08 05:15 AM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
No reason to NOT get a DF, but I'm really happy with my RAM HD Powergrip clutch set, and will probably be ordering another one for my upcoming 5-speed swap. Part of the reasoning behind that choice is that I've had great experiences with RAM's tech support as well. I can't say if that's par for the course in the clutch world, I've only had this one unit as a significant upgrade over stock-performance parts. I HAVE shopped around at Clutchnet.com, but so far it's 2 weeks and counting since I submitted a custom parts request through their web site and still no response. RAM emailed me back in 2 days, and then followed up immediately when I had other questions. That may not be an issue for you if you're ordering basically stock-type application parts, so all you really need are the parts that will work best for you. Just my
Clair
Re: 10.5" Clutch....what are you running ? [Re: Clair_Davis] #81949
06/30/08 11:41 AM
06/30/08 11:41 AM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
Yeah, nothing special at all in my combination.
Re: 10.5" Clutch....what are you running ? [Re: AlexP] #81950
07/01/08 09:01 PM
07/01/08 09:01 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
Re: 10.5" Clutch....what are you running ? [Re: AlexP] #81951
07/01/08 09:31 PM
07/01/08 09:31 PM
The Motor City
Stew4706 Offline
Stew4706  Offline
The Motor City
I have a Centerforce dual friction and I love it. You have to remove the over center spring on the pedal so the force required is minimal
Re: 10.5" Clutch....what are you running ? [Re: Stew4706] #81952
07/01/08 10:11 PM
07/01/08 10:11 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Hays Borg & Beck style behind a mild 360. Works great.
Re: 10.5" Clutch....what are you running ? [Re: AlexP] #81953
07/01/08 10:32 PM
07/01/08 10:32 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
We prefer the McLeod..
Check with Jamie @ Passon.
Just chucked a Centerforce into the dumpster..
Re: 10.5" Clutch....what are you running ? [Re: In_The_Pink] #81954
07/01/08 10:33 PM
07/01/08 10:33 PM
MI
marklock Offline
I tried too hard for a custom title
marklock  Offline
MI
Hayes street/strip behind my mild 360. Never any problems and I beat on it pretty good.
Re: 10.5" Clutch....what are you running ? [Re: marklock] #81955
07/01/08 11:01 PM
07/01/08 11:01 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
At what level to the pressure plates start to get unbearable ?
My buddy has a new Ram 3500lb pressure plate collecting dust, I do better with a stiff clutch than a soft clutch. Will my leg fall off ? I have very little stop and go traffic that I do, but I do intend of having a little fun. He also has a matching 23-spline clutch disc for it.
Re: 10.5" Clutch....what are you running ? [Re: AlexP] #81956
07/02/08 08:17 AM
07/02/08 08:17 AM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
I don't know what the RAM Powergrip HD PP is rated at, but it's not a lot different than the (worn) clutch in my old 87 Daytona. Still sucks in stop-n-go traffic, but not many clutches don't. My idea of a light clutch is the one in my 08 Honda Fit... you can almost press the pedal by sneezing on it. I would consider the RAM to be tolerable on a daily basis, which is just what I did with the car for a while.
Clair
Re: 10.5" Clutch....what are you running ? [Re: Clair_Davis] #81957
07/02/08 05:52 PM
07/02/08 05:52 PM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
Here is what I would suggest. McLeod 10.95 street package, moderate pedal effort, scalloped pressure plate to accept the larger disc. In stock.
http://www.brewersperformance.com/proddetail.asp?prod=MC1023
Wayne
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
Re: 10.5" Clutch....what are you running ? [Re: 64dodge572] #81958
07/03/08 01:58 AM
07/03/08 01:58 AM
BC Canada
cudasam Offline
cudasam  Offline
BC Canada
I used a Centerforce Dual Friction 10 1/2 inch behind a healthy but fairly stock 440, and it was the nicest clutch I've ever had. You could push the pedal to the floor with your hand. The engagement was perfectly smooth, and once you were rolling and hit the gas, it was locked up. I took the time to center the bellhousing with offset dowels, as I heard these clutches were sensitive to proper alignment. I also cleaned the flywheel and pressure plate with carb cleaner. Good luck
