69 Charger R/T stripe #81841
06/29/08 08:40 PM
06/29/08 08:40 PM
New York
tt455 Offline OP
tt455  Offline OP
New York
Is there a template or does someone know where to line up the rear stripes on the 69 Charger R/T? Like the distance between the pinstripes to the main stripe? Looks as if the wide stripe goes over the side marker lens.Thanks.
Re: 69 Charger R/T stripe [Re: tt455] #81842
06/30/08 05:57 AM
06/30/08 05:57 AM
MI, Lapeer
maximus Offline
maximus  Offline
MI, Lapeer
The R/T lettering has to line up on centerline of the bodyline in the quarter panel. The side maker should be dead center of the wide portion of the stripe. I sold my Charger so I can't give you measurements. Remove the side marker first because it does not get tape on it. Hope this helps.
Re: 69 Charger R/T stripe [Re: maximus] #81843
06/30/08 10:57 AM
06/30/08 10:57 AM
New York
tt455 Offline OP
tt455  Offline OP
New York
Thanks,any idea about the pinstripes? Should they be evenly spaced front and back?
Re: 69 Charger R/T stripe [Re: tt455] #81844
06/30/08 07:34 PM
06/30/08 07:34 PM
MI, Lapeer
maximus Offline
maximus  Offline
MI, Lapeer
Yes, the pin stripes are the same front and back. The distance from the wide stripe is about the same width as the pinstripe itself.
