69 Coronet R/T... fuel tank connections/lines?
#81803
06/29/08 07:36 PM
06/29/08 07:36 PM
Posts: 3,072 Farmland, IN
Ludington1
Farmland, IN
Can anyone post a picture or even just a description of where the connections go on a 69 Coronet R/T fuel tank? There is one line that starts at the sending unit and goes to the fuel pump... that one is no problem.
There are the other two connections towards the driver-side of the tank. Of those two, the one towards the passenger-side comes out to a short length of 5/16" rubber fuel line, and then about a 10" metal line which goes up to the bottom of the trunk floor, turns, and the open end of the metal line faces back towards the ground. The connection towards the driver-side goes again to a short length of rubber line and then a metal line that goes through a grommet in the trunk floor, acroos the trunk floor (inside the trunk) then back through a grommet and apparently down into maybe the frame rail? Should that longer line be connected to the vapor return line from the vapor separator?
Thanks in advance... I keep getting a strong gasoline smell in the garage and I need to try and get this figured out. The service manual doesn't really address this area very well that I have been able to find. With a full tank and after driving the car, I also am getting a bubbling/gurgling sound from the short length of metal fuel line described above.
Darren
Re: 69 Coronet R/T... fuel tank connections/lines?
[Re: Ludington1]
#81806
06/30/08 01:02 AM
06/30/08 01:02 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
Yes, that's it... are both of the 1/4" outlets just vents? The fumes seem to get so strong in the garage sometimes that my wife definitely doesn't like it, and I'm not too happy about it smelling that strong either... I am pretty sure that it is stronger than a "normal" old car.
Darren
That's because todays gas vaporizes way easier. If you fill a jar with todays pump gas and another with race gas, the pump gas will evaporate in about a week, and leave behind a nasty residue. It will take the race gas over a month to evaporate, and there will be almost no residue other than some of the fuels coloring.
I suppose you could add a filter or even some type of valve to the vent lines?
