Stainless Trim Question #81638
06/29/08 03:50 PM
06/29/08 03:50 PM
ontario canada
426lloyd Offline OP
426lloyd  Offline OP
ontario canada
when sanding out sratches on stainless how is it done. have been using scotch brite but takes a long time.is there a quicker way. thanks
Re: Stainless Trim Question [Re: 426lloyd] #81639
06/29/08 08:21 PM
06/29/08 08:21 PM
Minnesota
3twos Offline
3twos  Offline
Minnesota
I have used something like 320 to sand scracthes in stainless when it is real rough. I then use 800, then 1500 and then buff it.
Al & Sheila
Re: Stainless Trim Question [Re: 3twos] #81640
06/29/08 09:06 PM
06/29/08 09:06 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
