Page 3 of 3 1 2 3
Re: Help ID this 340 head setup, looks hardcore !!!!! [Re: 440Satellite] #815061
10/04/10 11:55 AM
10/04/10 11:55 AM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
And heres a good shot where you can see how loose it is, What would be the reason for such loose pistons.
Those old TRW Forged psitons were designed with a lot more room at the top to allow for heat expansion. What is the clearance in the wrist pin area, about 1 inch below the oil ring? I think you will find it is a lot tighter there and that is where they were measured for machining clearances.
Old Geezer Racing
Re: Help ID this 340 head setup, looks hardcore !!!!! [Re: SCATPACK 1] #815062
10/04/10 12:01 PM
10/04/10 12:01 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Did you CC the heads yet? They don't look to be milled excesively, mabey a little
Re: Help ID this 340 head setup, looks hardcore !!!!! [Re: HotRodDave] #815063
10/04/10 05:52 PM
10/04/10 05:52 PM
Hazlet, NJ
440Satellite Offline OP
super gas
super gas
Hazlet, NJ
Scatpack, I havent pulled the pistons yet so I dont know that the clearence is down low.
HodRod, yeah I cc'ed them yesterday, and they came in at 62cc's which surprized me. I have another set of J heads with a 2.02 stainless valve and it cc'ed at 68-69cc's. I quess they were milled a decent amount, plus I'm sure the manley valves add to it not nearly as dished as stockers.
1972 Duster 318 4 speed 1958 392 Hemi engine waiting to be built!!!!!
Page 3 of 3 1 2 3
