4speed iD? #81252
06/28/08 10:46 PM
06/28/08 10:46 PM
alberta
Publicbottle Offline OP
alberta
Where can i find the p/n on a 833 4speed to determine exactly what i have? Thanks in advance!
Re: 4speed iD? [Re: Publicbottle] #81253
06/28/08 10:58 PM
06/28/08 10:58 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
If it is one of the years with a VIN pad, list ALL the numbers on it, that is the easiest way.
Look on the passenger side of the case.
Part numbers (the last three digits) were usually painted on and they do not always survive.
Re: 4speed iD? [Re: Alaskan_TA] #81254
06/28/08 11:47 PM
06/28/08 11:47 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Re: 4speed iD? [Re: Publicbottle] #81255
06/29/08 12:01 AM
06/29/08 12:01 AM
IMGTX Offline
IMGTX  Offline
The tailhousing is the first sign.
Re: 4speed iD? [Re: IMGTX] #81256
06/30/08 10:57 AM
06/30/08 10:57 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
this will tell you more what you have than the numbers stamped on that pad .
VISUAL id of the trans as a whole tells you 90% of what you want to know
