Re: 2000 Dodge Ram 1500 running rough. . . .sometimes. [Re: MoparsnMissiles] #811854
09/23/10 01:47 PM
09/23/10 01:47 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
Another thing to check is the beer barrel intake. Underneath they use a piece of sheetmetal to seal it off. They blow the gasket all the time. I replaced mine with a piece from Indy and cured a lot of those type of problems. A sure indication is that it will start burning a little oil.
Re: 2000 Dodge Ram 1500 running rough. . . .sometimes. [Re: Cudajon] #811855
09/23/10 03:37 PM
09/23/10 03:37 PM
Grandville, Michigan
Dustya440 Offline OP
Thanks!
I'll check that out also when I put the sensor on it.
1969 Road Runner J Code 1970 Road Runner VOA 1971 Dart Swinger 1971 Cuda Vert 1973 Duster Pro Street 2003 Z06
Re: 2000 Dodge Ram 1500 running rough. . . .sometimes. [Re: Dustya440] #811856
09/23/10 04:00 PM
09/23/10 04:00 PM
Midwest
MoparsnMissiles Offline
Midwest
Thanks!
Lowest price on the sensor that I found is at O'Reilly's for $50. P/N is CSS813 for automatics, CSS812 for manuals (they cost more, $120).
Let me know if that solves the problem on your truck.
Re: 2000 Dodge Ram 1500 running rough. . . .sometimes. [Re: MoparsnMissiles] #811857
09/23/10 06:20 PM
09/23/10 06:20 PM
Rancho Cucamonga,Ca
3
392charger Offline
392charger  Offline
Rancho Cucamonga,Ca
I know it's a different year but my 2002 Ram 1500 with 360/Auto use to do the same thing. Would ramdomly start misfiring/popping thru the intake while driving. Almost like it was running on 6 or 7 cylinders. Then it would return to normal like nothing ever happened. The check engine light would come on but would be gone bu the time I got to the dealer. After several trips to the dealer they finally found the problem. It was a sensor located on the rear axle!? Go figure Been fine ever since though!
Re: 2000 Dodge Ram 1500 running rough. . . .sometimes. [Re: 392charger] #811858
09/23/10 07:26 PM
09/23/10 07:26 PM
Wow, again this sounds just like my truck.
Anymore info on what kind of sensor it is?
Re: 2000 Dodge Ram 1500 running rough. . . .sometimes. [Re: Dustya440] #811859
09/23/10 07:49 PM
09/23/10 07:49 PM
Atlanta
DartGTX Offline
DartGTX  Offline
Atlanta
ABS speed sensor reads the ring gear.
Re: 2000 Dodge Ram 1500 running rough. . . .sometimes. [Re: 392charger] #811860
09/23/10 07:52 PM
09/23/10 07:52 PM
Midwest
Midwest
OK, this is getting too wierd. A week before this engine problem appeared, the ABS and BRAKE warning lights came on on my truck. They went back out later the same day and are NOT on now.
The only sensor on the rear axle that I know of is the ABS sensor on the differential.
HOW does an ABS fault cause the engine to run poorly, misfire, etc???? I thought they were totally different systems.
Re: 2000 Dodge Ram 1500 running rough. . . .sometimes. [Re: MoparsnMissiles] #811861
09/23/10 08:03 PM
09/23/10 08:03 PM
Atlanta
DartGTX Offline
DartGTX  Offline
Atlanta
Rear wheel speed is read by ABS module...It passes the info. to the PCM and is used for vehicle speed and odometer. Fuel shut off occurs at 118 mph. If a erroneous reading is received by the PCM it WILL shut off injector pulse width.
Good luck
Re: 2000 Dodge Ram 1500 running rough. . . .sometimes. [Re: MoparsnMissiles] #811862
09/23/10 08:06 PM
09/23/10 08:06 PM
Rancho Cucamonga,Ca
3
392charger Offline
392charger  Offline
Rancho Cucamonga,Ca
I hear ya MoparsnMissiles. It was all too weird for me to figure out but the dealer eventually did. It was 4 years and 167,000 miles ago that this happened, but I'm almost positive it was the ABS you mentioned and it most definitely made it run like crap. Since the repair it has never done it again, and I have over 267,000 miles on it now. Untouched motor and trans. Best truck I have ever owned bar none!
Re: 2000 Dodge Ram 1500 running rough. . . .sometimes. [Re: 392charger] #811863
09/28/10 10:18 AM
09/28/10 10:18 AM
Well, I replaced the crank sensor and so far so good.
But the problem was intermittent before so time will tell.
I am driving the truck more than usual to see if the old problem reoccurs.
I'll back in a few days.
Thanks everyone for the suggestions!!
Re: 2000 Dodge Ram 1500 running rough. . . .sometimes. [Re: Dustya440] #811864
10/24/10 11:30 PM
10/24/10 11:30 PM
Midwest
Midwest
Any update yet on your truck?
