Who's got the biggest..... #811821
09/22/10 02:29 PM
09/22/10 02:29 PM
off the grid
340B5 Offline OP
340B5  Offline OP
off the grid
Base circle cam in a 59* Small Block with factory cam bearing bore. Also, what is the lift on the cam. I'm thinking of increasing the base circle on mine, being I have to buy a new cam.
Yeah, it's got a smallblock.
Re: Who's got the biggest..... [Re: 340B5] #811822
09/22/10 02:35 PM
09/22/10 02:35 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
If I understand correctly, the base circle is dictated by the
cam bearing bore and lobe lift.
The more lobe lift, the smaller the base circle.
Obviously it all has to fit through the cam bearings.
Re: Who's got the biggest..... [Re: S/ST 3040] #811823
09/22/10 03:30 PM
09/22/10 03:30 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
EXACTLY...
If you like drag racing, support your local track.
Re: Who's got the biggest..... [Re: 340B5] #811824
09/22/10 03:30 PM
09/22/10 03:30 PM
Alberta Canada
StrokerAspen Offline
Alberta Canada
The largest one I have is the comp cams "RX308R-8".
Not sure what the base circle is, but it is for a standard block. 275 @ .050" 284@.050" .658"/.661" lift with a 1.5 rocker.
I do not have this cam in my engine currently, I could check the base circle size later today...
-Kenny
Re: Who's got the biggest..... [Re: 340B5] #811825
09/22/10 03:42 PM
09/22/10 03:42 PM
Why do you want to increase
the base circle?
Re: Who's got the biggest..... [Re: Cab_Burge] #811826
09/22/10 03:53 PM
09/22/10 03:53 PM
Az
Crizila Offline
Crizila  Offline
Az
the base circle?
Fastest 300
Re: Who's got the biggest..... [Re: Crizila] #811827
09/23/10 01:35 AM
09/23/10 01:35 AM
off the grid
340B5 Offline OP
340B5  Offline OP
off the grid
Sorry, had to work.
The new lifters I bought have .050 less seat height and I don't want to extend the adjusters out too far.
