727 transmission fluid- check in NEUTRAL #81172
06/28/08 08:43 PM
06/28/08 08:43 PM
Canada
CrAzYMoPaRGuY Offline OP
Canada
So I answered a guy on another forum that the 727 transmission should be warmed to operating temperature, the shifter put momentarily in each gear, then the gear selector left in neutral at idle while checking the transmission fluid.
I have a feeling a few of them don't believe me....
I was always under the impression the 727 needed to be in neutral because of reduced line pressure in park, the converter doesn't "fill" in park or something...
Is there a technical explanation a layman can understand, or am I cuckoo?
(Don't answer that! )
CrAzYMoPaRGuY
Re: 727 transmission fluid- check in NEUTRAL [Re: CrAzYMoPaRGuY] #81173
06/28/08 08:50 PM
06/28/08 08:50 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
check in neutral cause the pump does not pump in park...
Tony
70 AARCuda Vitamin C
Re: 727 transmission fluid- check in NEUTRAL [Re: CrAzYMoPaRGuY] #81174
06/28/08 08:53 PM
06/28/08 08:53 PM
that is correct. for the "why" I had read that fluid is being pumped in neutral & that's when it needs to be checked which I always thought was strange as it's the opposite of when you check eng oil & as far as your sanity is concerned I am not qualified to comment on that.
Re: 727 transmission fluid- check in NEUTRAL [Re: RapidRobert] #81175
06/28/08 09:53 PM
06/28/08 09:53 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
yes check in neutrel the pump is pumping fluid anytime the engine is running however with the manual vavle in park the fluid is not being circulated unless you have installed an aftermarket manual vavle like comes in a transgo shift kit at that piont you can check it in park
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: 727 transmission fluid- check in NEUTRAL [Re: CrAzYMoPaRGuY] #81176
06/28/08 10:19 PM
06/28/08 10:19 PM
Eastern North Carolina
cyphre666 Offline
cyphre666  Offline
Your converter will leak trans fluid back into the trans. In neutral, with the pump pumping you know the converter is full
Re: 727 transmission fluid- check in NEUTRAL [Re: cyphre666] #81177
06/28/08 10:39 PM
06/28/08 10:39 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Tell them to read the dipstick. It says check in neutral on it. Mike
Re: 727 transmission fluid- check in NEUTRAL [Re: mopars4ever] #81178
06/28/08 10:50 PM
06/28/08 10:50 PM
p.c. FL.
mr.318 Offline
mr.318  Offline
p.c. FL.
Yea in neutral,the 904's to my 99 ram even says to check in neutral, Alot of people are just thinking gm or ford cause they check in park,See dodge is differnt
